Please provide a screenshot of chosen Windows features. Use postimage.org or similar for publishing screenshots.
I think, you should check command data. See Device Data tab in Communicator, scroll to the commands. Compare the command with manually sent commands.
If you can’t find the difference, post here the kpXXXX.txt and lineXXX.log. They are in C:\SCADA\ScadaComm\Log
The hour columns will be filled when the software works at least a hour.March 24, 2017 at 6:01 am in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2030
MikhailModeratorWill you be available tomorrow around 3pm EST
Probably yes.
March 23, 2017 at 5:04 pm in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2028
MikhailModeratorYou have a time left to get a remote session )
March 23, 2017 at 5:03 pm in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2027
MikhailModeratorWould I be able to have the “command to request” function triggered by an output signal from my PLC?
Yes. You need Automatic Control Module. Trial is available.
March 23, 2017 at 12:26 pm in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2025
MikhailModeratorMay be you can split your PLC into several sets of tags. Each of the set is a separate device in Rapid SCADA database. In this case it is possible to send a command to request required subdevice.
March 23, 2017 at 6:17 am in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2024
MikhailModeratorRequesting for partial set of tags it is not implemented by the current version of Rapid SCADA Modbus driver. This is a specific function. We can estimate custom development, but programming may be expensive.
If you describe the whole system, it helps to find out possible solutions.
March 23, 2017 at 6:04 am in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2023
Please could you provide an example?
What number of points (tags) is received every time and what number of tags depends on conditions?
It is a parameter Require password to send command of the Webstation application.
I think, we found out the answers to your questions yesterday by Skype 🙂
MikhailModeratorHi Martin,
I have sent you an email that contains details of free and commercial support options.
MikhailModeratorThank you.
Also you have to switch on ASP.NET 4.5 and HTTP Activation for WCF 4.5
What do you see by the link http://localhost ?-
This reply was modified 9 years, 2 months ago by
MikhailModerator
MikhailModeratorEmail support is available as a part of commercial Extended support http://rapidscada.org/services/technical-support/
In case of free support, use any other image hosting, ftp, file sharing service, etc.
