Viewing 15 posts - 5,266 through 5,280 (of 6,265 total)
  • in reply to: Setting Alarm threshold #2524
    You need to create input channels of calculated type that will store threshold. And create output channels to send command of setting threshold. Use SetVal formula for the output channels.
    The other question is how do you plan to react on threshold. For example you can create a formula to calculate status of input channel depending on the thresholds.
    in reply to: RapidSCADA on Linux/Ubuntu #2522
    I suppose, there are many text editors for XML which support collapsing and expanding XML nodes.
    in reply to: RapidSCADA on Linux/Ubuntu #2520
    Theoretically, it is possible to port the UI, but this is hard work. See this screenshot made by our user.
    in reply to: RapidSCADA on Linux/Ubuntu #2519
    gianguido, be free to ask follow up questions.
    What XML editor do you use in Ubuntu?
    in reply to: The averaging column in SCADA Admin input channels #2512
    1. Not “hourly real”, but “real”.
    2. Yes.
    in reply to: Limitation #2511
    Why do you expect any time limit? This is open source, i.e. no limits. Many users build the software by themselves from the source code.
    in reply to: How to execute communicator in Raspberry Pi3 #2510
    How to show UI of coomunicator?
    There is no UI on Linux, because it is a server. You should configure the software on Windows, and then copy configuration to Linux. I hope we will simplify this process in the future.
    in reply to: How to execute communicator in Raspberry Pi3 #2504
    .exe is OK for Linux when you use Mono Framework.
    If you performed the installation steps correctly, the daemons were created and Server and Communicator start automatically after restart RPi. You should check logs.
    in reply to: Source Code KpOpc.dll #2501
    Take the required DLLs in C:\SCADA\ScadaComm after installing Rapid SCADA.
    Then check their path in the project dependencies.
    in reply to: devices template Elements count && data conversion #2500
    1. 125 elements in one group of holding registers. Just add new group.
    2. By default 1 element is a word. You can choose the appropriate type of element in the template for float or double.
    in reply to: Source Code KpOpc.dll #2497
    Download the sources by this link.
    in reply to: Manipulating DAT files #2494
    The command line utility for converting snapshots.
    in reply to: Manipulating DAT files #2493
    DAT format is used for the configuration database, measured data (snapshots) and events. These are 3 different formats with the same file extension.
    The existing utility able to convert snapshots to CSV. I can share the link to it.
    One good guy gianguido is now working on other types of data.
    in reply to: Dashboard Export to PDF #2491
    Don’t delete an image please.
    in reply to: Dashboard Export to PDF #2490
    Thank you. I added this bug into our ticket tracker. When it is solved, I’ll write info here.
