manjey73ParticipantCan also change the display number according to British standard (11.5 instead of 11.5) at the same time leave the localization.
Unfortunately I don’t remember how I did it somewhere recorded, but could not find it.
Then, too, everything starts to work.
manjey73ParticipantThe features of the processors other devices (Little Endian o Big Endian)
Features of the sequence of bytes in the organization of the data transferWell, we don’t all speak the same English 🙂
I use online translation to learn examples in English as well as writing in the English forum.
manjey73ParticipantOptions for Standard commands to use formulas for IEEE (float)
Add to base formula
public double fRevers (int rev)
float q = Convert.ToSingle(CmdVal);
byte[] f = new byte[4];
byte[] o = new byte[4];
f = BitConverter.GetBytes(q);
Array.Copy(f,0,o,0,4);
if (rev == 1)
Array.Copy(f, 0, o, 1, 1);
Array.Copy(f, 1, o, 0, 1);
Array.Copy(f, 2, o, 3, 1);
Array.Copy(f, 3, o, 2, 1);
Array.Resize(ref o, 8);
Double ou = BitConverter.ToDouble(o,0);
return ou;
}Use the formula in the control channel – fRevers(1) Command type Standard, suitable for some Modbus devices.
Or try to use this formula
LINK{ buf[1], buf[0], 0, 0, 0, 0, 0, 0 }and change the variable type on input
ushort val = (ushort)Cmd;
manjey73ParticipantTicks
public static long Ticks()
DateTime now = DateTime.Now;
long time = now.Ticks/10000;
return time;
———————————–You want to work Ton
This reply was modified 8 years, 10 months ago by
manjey73.
manjey73Participanthttps://github.com/Manjey73/OpnenKPs/tree/master/KpRpi3 (readme – online translate)
https://github.com/Manjey73/OpnenKPs/releases/tag/KpRpi3 (use gpio 5-27, in archive use all gpio)
manjey73Participanthttps://s30.postimg.org/9etq90vmp/RStrig_Reset.png
Base formulas
ResetCnl
double ResetCnl(double val, int InCnl)
bool q = val > 0;
if (q)
q = !q;
CnlValSet(InCnl, 0);
return Convert.ToDouble(q);
RStrig
double RStrig (double set, double res)
bool s = set > 0;
bool r = res > 0;
bool q = r ? q = false : Val(CnlNum) > 0 || s;
return Convert.ToDouble(q) ;
Ton
int[] TonNum = new int[1];
long[] TonST = new long[1];
bool[] TonFlag = new bool[1];
public double Ton(double TonIn, long TonPT)
long ET = 0L;
bool q = Val(CnlNum) > 0;
bool ton_in = TonIn > 0;int res = Array.IndexOf(TonNum, CnlNum);
if (res == -1)
res = TonNum.Length;
Array.Resize(ref TonNum, res+1);
Array.Resize(ref TonST, res+1);
Array.Resize(ref TonFlag, res+1);
TonNum[res] = CnlNum;
}if (!ton_in)
q = false;
TonFlag[res] = false;
TonST[res] = 0L;
else
if (!TonFlag[res])
TonFlag[res] = true;
TonST[res] = Ticks();
else
if (!q) ET = Ticks() – TonST[res];
if (ET >= TonPT) q = true;
———————————————————I use formulas and module of automatic control to re-send the command
May still need to make the formula entry a bit to the desired value, if necessary.Sorry for my English, is machine translation
