MistralParticipantthanks, yes … I had an error in the bash script that did not copy the BaseDAT files \ *. dat then I noticed that the modification dates were always the same … etc
salute Mikhail
MistralParticipantI apologize … as I’m not very practical with linux / raspberrypi, I checked out better that the files and tables coming from w10 according to the “how_to_use.txt” instructions were not overwritten despite superuser privileges … good work at all
MistralParticipantHi, in win10 I created a schema with “schema editor” and saved it in “C: \ SCADA \ Interface \ Servers \”, I defined the path in the table “interface” and “interface object” in the “right” table. .. the schema is visible in the mozilla browser (http: // localhost / scada “… I moved to RaspberryPi following the directions in” how_to_use.txt “… I used the Chromium browser (http: // localhost: 8084 /scada/Login.aspx) and logged in … I see only the default schema while mine is not present …
can you help me understand what to do to solve it?
MistralParticipantHi manjey73, thanks, I’m Italian and wrapped I find it difficult to understand the automatic translations, I think it is reciprocal and we can not do anything, I only wonder if the screenshots were in English … because it is difficult to translate from the images … everything here! :>
MistralParticipantI’m evaluating the insights I’ve been given to here … manjey73 sent me some screenshots that I’m very useful, if I could have others, possibly in English, with various settings would help … if possible .. . thank you
MistralParticipantThere are no girls in the examples. You see in the webpage showing sample images (https://postimages.org/) as advertising, I thought you knew it because in other examples of your forum I had already noticed this. : -J
MistralParticipanthi manjey73,
🙂 beautiful russian girls! … thanks for the examples you sent me … I have to understand them trying to translate them from the Russian … I will carefully analyze them
sorry but I have to suspend the activity for a short time,
in the meantime I will reflect on what has been said so far,
I hope to find you available
I’m not sure I understand well (maybe it’s the automatic translator), the sketch just needs me to manually test what i want to get regardless of quickdraw but the goal is to use rapidscada via modbustcp …
MistralParticipantHi Mikhail,
i send you the current setting of “Automatic Control Module” … i hope i have suggestions … thank you
i have the “Automatic Control Module”, i have rapidscada’s pc.
I’m evaluating the script you sent me.
But to make sure I explained my intent to you, I am sending you a list of a simple Arduino sketch where I realized what I would like to get from rapidscada scheme.
MistralParticipantHi manjey73, thanks for the availability and patience of a RapidScada neophyte, I include three images representing 1) electrical input and output PLCs, 2) input channel and ScadaCommunicator administrator table, 3) Scada Scheme I did for tests where I see the simulated temperature I receive in addition to a dynamic picture that changes when the temperature changes. Now I would like to realize with rapidscada that if the temperature exceeds a certain value rises to 5Volt A0.5. I hope that what’s said is useful to suggest a solution.
MistralParticipantThanks, but I would like to implement temperature control (swinging from 900 to 1100) on rapidscada so that if it exceeds 1000, “voltageWrite (A0_5, 5000) is activated”. I do not know how I could better clarify, sorry.
MistralParticipantHi Mikhail … I have the module but I do not know how to set the formula in rapidscada … in the arduino sketch i have implemented …
if (Mb.MbData[6]>1000)
voltageWrite(A0_5, 5000);
voltageWrite(A0_6, 0);
else
voltageWrite(A0_6, 5000);
voltageWrite(A0_5, 0);
}that works, can you help me?
MistralParticipantthanks … I apologize … I use an automatic translator … anyway I meant that I have a temperature input that if exceeded a certain value I have to activate a small engine connected to the plc that starts giving 5volt energy
