manjey73ParticipantWell, you just need to add +8 hours to display in another Scada. The Scada variable itself is stored in double format and it is more convenient to already have a DateTime structure in it
You can see how to add the clock directly to UTC time, it seems that everything is in seconds there. And add this addition to the formula above and only then convert to DateTime or store real UTC time in one cell and already perform conversions and show it in the pre-calculation one.
manjey73Participantdouble dtFromUtc(double utcTime)
var epoch = new DateTime(1970, 1, 1, 0, 0, 0, DateTimeKind.Utc);
return epoch.AddSeconds(utcTime).ToOADate();
}Add to the Reference List of formulas that are not there. And in the input channel, use this formula with the Date, Time or Date and Time
I don’t know if I understood correctly what you need
This reply was modified 5 years, 1 month ago by
manjey73.
manjey73ParticipantThere are some problems with access rights. Configuration files are written from the system user, and you open the Web from a regular user
manjey73ParticipantOfficially, you can’t. But the ways of the Lord are inscrutable 🙂
manjey73ParticipantThe current data must be saved in the Windows environment. What OS are you using ?
manjey73ParticipantWhat is RP ?
manjey73ParticipantIt is clear, so I had another reason for the Illegal data error error, since it crawled out when writing the float parameter in 5.8.3, I had to throw the library from 5.8.2 to make the command work.
manjey73ParticipantTake the Modbus driver from the previous version 5.8.2 temporarily until the error is fixed
August 11, 2021 at 7:21 am in reply to: Stop auto control module without stop/restarting scada server #9390
manjey73ParticipantMoreover, stopping the operation of the control module from the WEB should be performed only in part of the required KP, for example, during technological inspections of equipment.
August 11, 2021 at 7:19 am in reply to: Stop auto control module without stop/restarting scada server #9389
manjey73ParticipantSuch functionality would be useful even from a WEB system. I will also support the question
manjey73Participant
But as mentioned above, the page loading will be long, it is still better to make copies of the elements and change the channels. A bit not for such things inserting a schema into another schema
manjey73ParticipantInstallation of Webstation Plugins
7. Download data from the server
manjey73ParticipantOverload the server and also make the Ctrl+F5 command in the browser to update.
After you have entered the registration key, you need to download the data from the server, and then upload it back to the server.This should be described in the documentation.
This reply was modified 5 years, 2 months ago by
manjey73.
manjey73ParticipantYou can get a temporary computer code for testing, and you need to pay for the code that will work in the WEB, if you have a separate server, Web server
manjey73Participant(note: setting of “../Scheme/Scheme. aspx?viewId=35” does not work).
In order for the link to work, you need to add this scheme to the views, give it rights, configure the display as a separate view, then you will know its ID, then you insert this view into another scheme with this link. The ID number will be the one that you will be assigned by the system. To hide this view from the list in the tree, you need to set the”Hide” checkbox
You will still have to create 128 views and hide them, and specify them for frames
