otrotabi
ParticipantYes ! Now it works, sorry to waste your time. I have another question to ask regarding the automatic module but I will open another topic. Thank you.
otrotabi
ParticipantHi, thanks for your fast answer. What I am doing is “Ctrl C + Ctrl V” from what I am writing in the Automatic Control Module into the string that triggers an email from the manual configuration, so I am pretty sure the string is not the problem. I only add “no” to the message subject in order to be able to tell the messages apart and not get confused.
Ok, I got a new trial key, here are the results from Scada/ScadaServer/Log/ModAutoControl log
2017-03-27 07:48:18 Start ModAutoControl module
2017-03-27 07:48:18 Check “Automatic control module” registration:
Registration key is valid. Expiration date is 28/03/2017
Computer code: =A698CC14BAB3810A-C0BF277D3506B8DD-54CE811CD7B94DD5-2438CFFADF78EC77-2EE36D9C93F80512-D4E66955529E0CBD-B46517385A6088F3-AA3E7AFB358BD113-B0831251637B199E-871A4AAA71712C45-778BDCBA0E2222F5-242579DE0D2A7117-2CB6EDDFAB87CEEE-0790008BD45C11B4-39AACF95295CF8BB-4DBEE1E4E06A7DFE=
2017-03-27 07:49:04 Trigger “Alta temperatura” raises
2017-03-27 07:49:04 Send command to Device 401. Command number: 1
2017-03-27 07:55:09 Trigger “Alta temperatura” raises
2017-03-27 07:55:09 Send command to Device 401. Command number: 1
2017-03-27 07:58:40 Trigger “Alta temperatura” raises
2017-03-27 07:58:40 Send command to Device 401. Command number: 1This is the result form kp04 log
Device 41 “Email sender”
DLL : KpEmail
State : normal
Comm. session : time is undefined
Command : 27/03/2017 07:53:09Comm. sessions (total / errors) : 0 / 0
Commands (total / errors) : 1 / 0
Requests (total / errors) : 0 / 0Current device tags data
| Signal | Name | Value | Channel |
| 1 | Sent emails | 1 | 401 |
+——–+————-+——-+———+No archive data
No events
Commands (recent 10 commands)
| Num. | Date and Time | Description |
| 1 | 27/03/2017 07:53:09 | Command: type=Binary, device=41, number=1, data=4A6F73653B5072756562… |
+——+———————+————————————————————————-+I think this last line was added after I sent a manual email.
This is line004 log
Waiting for commands…
2017-03-27 07:48:25 Initialize communication line 4 “Email”
2017-03-27 07:48:26 Start communication line 4 “Email”
Loading address bookWaiting for commands…
2017-03-27 07:53:09 Command to the Device 41 “Email sender”, type: KpEmail
Email has been sent to josetabisi@tecnitower.comWaiting for commands…
This is ScadaCommSvc log. I am not sure what it means, but it looks like the module is doing it`s job
2017-03-27 07:48:23 <JOSEHP8540><SYSTEM><ACT> ScadaCommService 5.0.0.1 is started
2017-03-27 07:48:24 <JOSEHP8540><SYSTEM><ACT> Load device library: KpModbus.dll
2017-03-27 07:48:24 <JOSEHP8540><SYSTEM><ACT> Load device library: KpOpc.dll
2017-03-27 07:48:25 <JOSEHP8540><SYSTEM><ACT> Load device library: KpSms.dll
2017-03-27 07:48:25 <JOSEHP8540><SYSTEM><ACT> Load device library: KpEmail.dll
2017-03-27 07:48:25 <JOSEHP8540><SYSTEM><ACT> Load device library: KpSnmp.dll
2017-03-27 07:48:25 <JOSEHP8540><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2017-03-27 07:48:26 <JOSEHP8540><SYSTEM><ACT> Start communication lines
2017-03-27 07:48:26 <JOSEHP8540><SYSTEM><ACT> Start receiving commands
2017-03-27 07:49:04 <JOSEHP8540><SYSTEM><ACT> The command is received from SCADA-Server: type=Binary, device=401, number=1
2017-03-27 07:53:09 <JOSEHP8540><SYSTEM><ACT> The command is received from file: type=Binary, device=41, number=1
2017-03-27 07:55:09 <JOSEHP8540><SYSTEM><ACT> The command is received from SCADA-Server: type=Binary, device=401, number=1
2017-03-27 07:58:40 <JOSEHP8540><SYSTEM><ACT> The command is received from SCADA-Server: type=Binary, device=401, number=1
2017-03-27 08:14:11 <JOSEHP8540><SYSTEM><ACT> The command is received from SCADA-Server: type=Binary, device=401, number=1Regarding configuration of ModAutoControl, it says:
Server: localhost Port: 10000 Timeout: 10000 User : ScadaServerCtrl Passsword: *****, I have not touched the password, but could it possibly be wrong ?
In Device 401,Command 1, I have:
Device: 401 Command: 1 Binary
String: User;Mail Subject;Mail textPlease let me know if you need furhert info.
otrotabi
ParticipantHi, I am able to send emails in Manual Mode from the Communicator Module. I also downloaded Automatic Control Module, asked for a trial key, configured a channel data trigger (High temperature ) and get the confirmation from inside the module log that the trigger was detected (Trigger “High temperature ” raises) and the command to email device was sent (Send Command to Device 401. Command number: 1). However I do not get any emails. What else do I need to configure ?
