huary
ParticipantOK
Thankshuary
ParticipantOK,Thanks
huary
ParticipantYES.
The port 10000 is used by SangforSP
Thanks to Mikhailhuary
ParticipantI can connect to SCADA-Server using Hercules utility
Module IP:127.0.0.1 Port:10000
The Received/Sent data Panel showes “Connected to 127.0.0.1”OS: Win10,
IIS version:10.0.14393.0
installed .net framework:4.0,4.5,4.6Can you help me ?
Best regardhuary
ParticipantThe port 10000 is used by ScadaServerSvc,but i still unable to login, can you tell me why? thanks
ScadaServerSvc.exe 13884 TCP L-PC 10000 L-PC 0 LISTENING
huary
Participanti also have this problem
this is Server Log,it is runing normal
SCADA-Server
Started : 20/02/2017 16:48:56
Execution time : 00:19:31
State : normal
Version : 5.0.0.0Connected Clients
NoThis is web log,Can you tell you why i canot login?\
2017-02-20 16:54:44 <L-PC><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2017-02-20 16:54:49 <L-PC><DefaultAppPool><EXC> Error connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2017-02-20 16:54:49 <L-PC><DefaultAppPool><ACT> Disconnect from SCADA-Server
2017-02-20 16:54:49 <L-PC><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
at Scada.Client.DataCache.RefreshBaseTables()
2017-02-20 16:54:49 <L-PC><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2017-02-20 16:54:49 <L-PC><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1 -
