MohanadOdema
ParticipantI’m sorry but I’m feeling lost with using the formulas. Am I supposed to enter the entire function you stated in the formula space as shown in the screenshot ?
MohanadOdema
ParticipantFor now I need a special time for sending the coomands.
In my design I want for example at 3:15 open relay switch and 3:30 close relay switch.
And later if I access my scada site I could cchange those times completely.
MohanadOdema
ParticipantI’m not sure I understood that correctly. Does this flag value represent if the checked time is equal to the real time of my machine ?
I created the channel but how can I check time in a channel’s formula ?
MohanadOdema
ParticipantI have a time trigger for a certain command. I want to be able to change the time settings for this trigger from my Scada web page on a browser directly without the need to access the control module from the Scada Server.
MohanadOdema
ParticipantNevermind I got it working now. thanks a lot.
MohanadOdema
ParticipantThe module can be tested to send automatic commands during the 10 minute trial period, can’t it?
I’m trying to send a simple command that I configured before but it doesn’t seem to be working. Is further configuration needed on the module properties ?
MohanadOdema
ParticipantYeah that was it, it’s working now thanks.
MohanadOdema
ParticipantIt is not sending emails from the communicator UI. I tried adding the same credentials in the Scada Admin and it is not working still.
Here are some screenshots
https://www.dropbox.com/s/x9tfllbbppozys5/communicator2.png?dl=0
https://www.dropbox.com/s/l00gyb2puj5c39p/communicator3.png?dl=0
https://www.dropbox.com/s/c3uz8gz0gczym61/communicator.png?dl=0MohanadOdema
ParticipantNevermind it worked. Apparently updating windows 7 version and reinstalling .NET did the trick somehow.
Cheers mate 🙂
MohanadOdema
ParticipantYeah the IIS features are like those.
Here is the image https://www.dropbox.com/s/jqwz3oi4ykdso4u/2.png?dl=0
I also upgraded my Windows to Windows 7 SP1.
MohanadOdema
ParticipantWindows 7 64 bits
MohanadOdema
ParticipantThanks Nevermind I worked the ScadaWeb Server at last!
However I still have a problem in the Scada Communicator. The channels are not bound to their device tags even though I created the required channels in the Scada Admin with the appropriate signals to match those in the template of my device in the ScadaComm.
What can be the cause of this problem ??
MohanadOdema
ParticipantJust to make sure you completely understand my design, the Scada TCP server is on the RPi while the Scada TCP client on which I want to implement my web server is a local PC connected to the TCP server by Ethernet cable.
if my understanding is correct, I left the Server as localhost and port 10000. I added the sets and views as instructed in your documentation. However, when I type in the URL http://localhost/Scada, it gave me 404 error “Not Found The requested URL /Scada was not found on this server.”
Did I miss something ?
MohanadOdema
ParticipantAnother Question if you don’t mind,
I want to utilize the Scada Web service, first should I change the server to the ip of the RPi on which the Scada Server is set or should I leave it as it is ?
Second: Do I need a specific port number or leave it at 10000 ?
I tried setting server to localhost and port number to 10000 and then I tried http://localhost/Scada and it gave 404 error. I also tried http://localhost/Scada:10000 and it gave me 403 forbidden access error.
MohanadOdema
ParticipantYeah it is working now.
Much gratitude for your time and effort.
