fahrur
  • in reply to: Database storing #1156
    fahrur
    yes, its use javascript ajax script to load data every second
    in reply to: Database storing #1153
    fahrur
    i use highchart spline tipe updating each second, here is highchart demo http://www.highcharts.com/demo/dynamic-update
    in reply to: scada server (state: error) #1119
    fahrur
    solved, thanks mikhail, the problem is there no data inside incnl.data file
    in reply to: Modbus TCP multiple connections slow #1103
    fahrur
    Thank you for fast respond, now i split polling into several communication lines. Its collecting without problems 😀
    in reply to: Export data module manual exist? #1091
    fahrur
    hi mikhail,
    i cant find any documentations using ModDBExport modul, and database / table configuration inside mysql,
    i try to export to my sql heres the log:
    ModDBExport.log :
    ____________
    2016-05-06 14:41:37 Start ModDBExport module
    2016-05-06 14:43:20 Module ModDBExport is stopped
    2016-05-06 14:43:22 Start ModDBExport module
    2016-05-06 14:44:30 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
    2016-05-06 14:44:31 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
    ____________
    and
    ModDBExport.txt :
    ____________
    Export Data Module
    State: normal
    Data Sources
    1. MySQL – 192.168.10.71; state: normal; in queue cur/arc/ev: 100/0/0; exported cur/arc/ev: 0/0/0; skipped cur/arc/ev: 1149/0/0
    ____________
    thks.
    • This reply was modified 10 years, 6 months ago by fahrur.
