Wan
Participantbeacuse “settFileName” is null.
Wan
ParticipantMy SCADA-Server service and Server-Communicator are running.
Wan
Participant<ERR> Unsuccessful login attempt: admin – server communication settings is not loaded??
Wan
Participantyes, I do it.
But also have this error
Error:Insufficient rights.
——————————-public partial class ScadaScheme : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
// получение данных пользователя
UserData userData = UserData.GetUserData();// вход в систему для отладки приложения
if (!userData.LoggedOn)
string errMsg;
userData.Login(“admin”, “12345”, out errMsg);
}// проверка входа в систему
throw new Exception(CommonPhrases.NoRights);// инициализировать данные приложения SCADA-Схема
SchemeApp.InitSchemeApp(SchemeApp.WorkModes.Monitor);
}Wan
Participantif (!userData.LoggedOn)
throw new Exception(CommonPhrases.NoRights);Error:Insufficient rights.
Wan
ParticipantScadaScheme.log “<ERR> Unable to load scheme because user is not logged on. Host: ::1”
I don’t know Sequence of operations
Wan
ParticipantI changed my viewSet as below scheme/ScadaScheme.aspx?viewSet=0&view=1.
but also error“Error is :Не удалось загрузить схему”
My original viewSet is “scheme/ScadaScheme.aspx?viewSet=3&view=1”
Thanks for the hard work
Wan
ParticipantThank you for you.
can I Suggest your new scheme Functions?Wan
ParticipantI solved the “wcf service error:遠端伺服器傳回一個錯誤: NotFound” problem.
I deleted my pc all .net and installed the .net 4.5.
I successfully launched.
but installed the .net 4.0 error also exist.
Thank you very much.Wan
ParticipantThank you Mikhail,I email for you and I have others problems
Wan
ParticipantI deleted my pc all .net framework and install .net framework 4.0
enter: http://localhost/scada/scheme/ScadaSchemeSvc.svc
my screenshot content is
“Application error: Security settings for this service require ‘Anonymous’ Authentication but it is not enabled for the IIS application that hosts this service.”
Wan
ParticipantОшибка при работе приложения: 主機 (‘IntegratedWindowsAuthentication’) 上設定的驗證配置不允許繫結 ‘BasicHttpBinding’ (‘Anonymous’) 上設定那些配置。請確認 SecurityMode 已設定為 Transport 或 TransportCredentialOnly。此外,透過 IIS 管理工具、ServiceHost.Authentication.AuthenticationSchemes 屬性,在應用程式組態檔的 <serviceAuthenticationManager> 元素變更此應用程式的驗證配置、更新繫結上的 ClientCredentialType 屬性或調整 HttpTransportBindingElement 上的 AuthenticationScheme 屬性可以解決此問題。
Wan
Participantno,my pronlem also exist ..
Wan
ParticipantThanks you.
but my pc is win7,so I don’t have NET 4+ in my windows features ,only have net 3.5.1
so win7 can’t run ???
I have try install net 4+,but my windows features can’t find .net 4+ .
Do you have others method?Wan
Participantmy ScadaScheme error: Не удалось загрузить схему
