mails2saurabh
ParticipantA
mails2saurabh
ParticipantYou need to check your voltage source, it looks it is not sufficient…
mails2saurabh
ParticipantGot it… Installed scada web on the network machine.. Now able,to connect.. Earlier,was trying to access using internet explorer directly..?
mails2saurabh
ParticipantYes, I am able to open on the network (http:// 172.16.0.3:80/scada), but not able to login through network. However, on the local machine I am able to login.
Note: 172.16.0.3 is my local host and 172.16.0.1 is network machine on which , I am able to open ,but not able,to log in.
User name: admin
Password:12345.
Suggest!!mails2saurabh
ParticipantBut using port 10000, I was not able to connect to scada server,on a network machine using internet explorer. Using port 80 , I could connect, any how , I will check this to open on local host first !!
mails2saurabh
ParticipantError code on,ScadaServerSvc
Error start communication with,client: An attempt was made to access socket in a way forbidden by its access permission.This error started, after I made changes to , user name password and port no., changed to 80, made all usernames: admin on the interface.
Suggest!! What needs to be corrected??
mails2saurabh
ParticipantAfter rebooting localhost, I am not able to login on localhost also..
mails2saurabh
ParticipantError is – Unable to login: Server is unavailable. Used port in 80
mails2saurabh
ParticipantI m presently in front of system…
mails2saurabh
ParticipantThanks, I am able to open the web interface on the network, but I am not able to login using user: admin , password: 12345.
However, with the same user name and password , I am able to login on the localhost. Help !!mails2saurabh
ParticipantAs suggested, I installed scada communicator on the opc server, I am not able to browse the opc server. I changed ip address,in the common parameters in the server option. But I am getting following error when importing communication lines.
“error connecting to scada server: A connection attempt failed because the connects party did not respond after a period of time, or a established connection failed because connected host failed to respond 172.16.0.3:10000.”Please suggest.
mails2saurabh
ParticipantOk,I will come back after checking ?
mails2saurabh
ParticipantHow will scada server / scada web will communicate to scada communicator service on network??
mails2saurabh
Participant1. I understand that.. OPC will not work , but Modbus Will work??
2.When are we expecting the next version ?? For scheme view to be functional.mails2saurabh
ParticipantThanks for reply. Is it tested for full functionality on raspbian ??
