sancudo
  • in reply to: WCF Service error #615
    sancudo
    Managed to solve it by using DSIM in the command prompt in one of the replies of the first link.
    After aplying that I started getting the following error
    Server Error in ‘/Scada’ Application.
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: The value of the property ‘controlRenderingCompatibilityVersion’ cannot be parsed. The error is: Version string portion was too short or too long.
    Source Error:
    Line 4: <compilation targetFramework=”4.0″ />
    Line 5: <roleManager enabled=”true” />
    Line 6: <pages controlRenderingCompatibilityVersion=” ” />
    Line 7: </system.web>
    However, I fixed it by putting 4.0 instead of leaving line 6 blank which is the line of the error.
    Thanks for all the help and availability!
    in reply to: WCF Service error #613
    sancudo
    Windows 8.1
    in reply to: WCF Service error #609
    sancudo
    Well, seems I made some progress, now I’m getting this error
    WFC servie error: [ResponseContentTypeMismatch
    Arguments: text/html; charset=utf-8,text/xml; charset=utf/8,1024,
    <!DOCTYPE html PUBLIC “-//WC3//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org&#8230;
    The ScadaWeb.log throws this as the associated error
    2015-10-13 14:55:39 <MYCOMPUTER><DefaultAppPool><EXC> Application error: Path ‘/Scada/scheme/ScadaSchemeSvc.svc’ is forbidden.
    at System.Web.HttpForbiddenHandler.ProcessRequest(HttpContext context)
    at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Page: http://localhost/Scada/scheme/ScadaSchemeSvc.svc
    And trying to access directly to the .svc throws this in the browser
    Any way to enable the access? is it because of firewall or is there another reason?
    • This reply was modified 11 years ago by sancudo.
    in reply to: WCF Service error #606
    sancudo
    The ScadaScheme log provides no information. The only thing in ScadaWeb that could be something is this, which i’m not sure what kind of file it is.
    2015-10-13 06:27:29 <MYCOMPUTER><DefaultAppPool><ACT> SCADA-Server unable to open file [Ev]\e151013.dat
    Only log before that is me login in. Not sure if this has something to do with it. When I attempt to load the default scheme and get the error, no lines are added to the log file but the time of that is not far off from about 5 minutes from one of the times when I got the error.
    I get an error 404.3 when trying to Access the .svc like that.
    in reply to: WCF Service error #601
    sancudo
    I’m having the same problem, opening SCADA-Web with the different URLs suggested didn’t work for me. It throws the same error anyway.
    Are there any other alternatives to solve this?
