Viewing 15 posts - 3,511 through 3,525 (of 6,392 total)
  • in reply to: Channels in memory only #7805
    So, sounds like if I set the channel to a special null archive,
    like /dev/null in linux, that channel’s logging is disabled.
    I think, this is different.
    in reply to: Continuing a calcuation after restart ? #7804
    CnlVal contains value that is received from controller.
    Val() is a function that retrieves current channel value. Channel values are loaded on start.
    in reply to: Auto Control Module don’t load all triggers #7798
    Thank you for the screenshots.
    Please check the following:
    1. Is there the trigger for 7239 in ModAutoControl.xml that is located in C:\SCADA\ScadaServer\Config?
    2. Is there any mention of the trigger name in C:\SCADA\ScadaServer\Log\ModAutoControl.log ?
    What are the versions of SCADA-Server and ModAutoControl.dll?
    in reply to: Continuing a calcuation after restart ? #7797
    You could create a property like
    double MyVar
      get
        return Val(101);
      set
        SetVal(101, value);
    Where 101 is the input channel number. Channel of the calculated real type. Note: I didn’t tested it.
    in reply to: Not Receiving Data from Request – Modbus #7788
    Do you think this would cause a problem in communication?
    It is highly possible. If I were you, I would connect another converter instead of PLC and check if data are received from the 1st converter.
    If your converter has more than 1 RS-485 port, you can perform this test using the single converter.
    in reply to: Channels in memory only #7787
    This feature will be supported in the next generation Rapid SCADA 6. It will be possible to choose for a channel, which archives it is written to.
    I saw there is a command type named REQUEST.
    By sending the command of the Request type you can perform a device poll out of turn. It is useful when there are many devices and an operator wants to poll a device immediately.
    in reply to: Continuing a calcuation after restart ? #7786
    To save and load values you can store them into input channels. Current values of input channels are loaded on start.
    Otherwise, it’s better to develop a Server module and store values in a file.
    in reply to: Access Rapid SCADA data from Node-RED #7785
    Will create a release. Thanks.
    in reply to: Auto Control Module don’t load all triggers #7784
    We need to clarify the issue. Could you provide links tp the screenshots of the settings, describe expected and actual behavior?
    in reply to: scheme editor bug when scrolling #7782
    Fixed. The problem appeared because the scripts in the editor were not updated. Now these files are replaced in the distributive package without changing version number. You should download it again and update files in
    C:\SCADA\ScadaSchemeEditor\Web
    C:\SCADA\ScadaWeb\plugins\SchemeEditor
    in reply to: Automatic Control Module integration #7769
    Check the command type of the trigger (standard or binary).
    To avoid infinite loop:
    1. You need to create another output channel for the 2nd command.
    2. Or check the command value in the trigger.
    in reply to: Not Receiving Data from Request – Modbus #7768
    According to the log file, you can connect to the converter, but there is no response from the device.
    Check the following:
    1. The device ID is correct (is set to 5).
    2. RS-485 wires are correct. Try swapping A and B wires.
    in reply to: scheme editor bug when scrolling #7759
    I will check it and write here.
    in reply to: Administrator Find and Replace Bug #7758
    Good. The fix will be included in the next release. Thank you.
    in reply to: Automatic Control Module integration #7757
    You need to create a command trigger in the module settings. Under this trigger create a command to send “release command”. If you provide screenshots of the settings, I can check them.
