August 29, 2024 at 11:41 am in reply to: Modbus TCP No sending command for write new value to slave device #15264
nakorn
ParticipantHi Mikail, Thank you for your help. Now I can write data from the Webstation.
August 24, 2024 at 7:52 am in reply to: Modbus TCP No sending command for write new value to slave device #15225nakorn
ParticipantHi Mikail. I need to send a command to write updated data to register 6 of slave ID2. The command frame should be “2-byte transaction id, 0x00 0x00 0x00 0x06 0x02 0x06 0x00 0x06 0x01 0x2C”
August 22, 2024 at 3:06 pm in reply to: Modbus TCP No sending command for write new value to slave device #15210nakorn
ParticipantSory Mikhail, I found it.
2024-08-22 22:03:02 Command 06 to the device [2] Tim-94n-4ch
Error: invalid command2024-08-22 22:03:02 Session with the device [2] Tim-94n-4ch
Request element group “Tim-94n-4CH”
Send (12): 79 BD 00 00 00 06 02 03 00 00 00 0D
Receive (7/7): 79 BD 00 00 00 1D 02
Receive (28/28): 03 1A 02 EE 02 08 01 90 40 18 01 F4 00 C8 01 2C 01 90 00 00 00 00 00 00 00 00 00 00
OK
”August 22, 2024 at 10:26 am in reply to: Modbus TCP No sending command for write new value to slave device #15208nakorn
ParticipantThis is information in the log file when I send a command.
2024-08-22 17:18:18 [IMUM04][IMUM04$][ACT] Command with ID 7405906156018121508 to the device 2 from C:\Program Files\SCADA\ScadaComm\Cmd\cmd_7405906156018121508.dat
2024-08-22 17:19:03 [IMUM04][IMUM04$][ACT] Command with ID 7405906350209285025 to the device 2 from C:\Program Files\SCADA\ScadaComm\Cmd\cmd_7405906350209285025.dat
2024-08-22 17:19:50 [IMUM04][IMUM04$][ACT] Command with ID 7405906556098538204 to the device 2 from C:\Program Files\SCADA\ScadaComm\Cmd\cmd_7405906556098538204.dat
2024-08-22 17:19:56 [IMUM04][IMUM04$][ACT] Command with ID 7405906580700786187 to the device 2 from C:\Program Files\SCADA\ScadaComm\Cmd\cmd_7405906580700786187.dathttps://drive.google.com/file/d/1J5czW3e5s040Lglbo2GiegaZOPVVueUc/view
August 21, 2024 at 1:45 pm in reply to: Modbus TCP No sending command for write new value to slave device #15196nakorn
ParticipantThank you, Mikhail. here is a short video. clip.https://drive.google.com/file/d/1MmwjoQg3lcLW2UWyoqEmXKP69ghybPqu/view
I can’t find a command to send to the Modbus slave simulation.August 21, 2024 at 1:27 am in reply to: Modbus TCP No sending command for write new value to slave device #15183nakorn
Participantadd new device
https://drive.google.com/file/d/1Dh0OI6Hkqma0XsUntE0oAx2nl4cR8sPS/view
communication log
https://drive.google.com/file/d/1qwHWG7FeoDLH-7XHQw4DiunJ27zr4Mic/view
no new device in device table
https://drive.google.com/file/d/1p02fXUHuIKNarwDE__XSmxBO2WXG8L5L/viewAugust 20, 2024 at 9:40 am in reply to: Modbus TCP No sending command for write new value to slave device #15179nakorn
ParticipantThank you, Mikhail. Now I deleted the project and made a new one, which worked. Could the problem be from adding a new device on Device Polling?
