paulinapau
ParticipantI will consider your advice. Thank you.
paulinapau
ParticipantI think this is the final solution, isn’t it? Okay then… But, is it possible for me to use a cloud server instead?
paulinapau
ParticipantWait, sorry! I put the wrong screenshot, oh my… here’s the correct one!
paulinapau
Participanthey sorry. i’m using rapid scada v6 and os version windows 10. and I’m already installed it in my computer but it’s not showing in my IIS manager.
herepaulinapau
ParticipantBefore I tested it, where I only put the output channel as the channel in the manual export channel. But it’s still get the same error… Could you describe what should I do to get the export success (except changing the Rapid SCADA version)?
here’s the channel output
https://drive.google.com/file/d/1pLOGQL2zLvI1YGpdy9lH25C6gB8p6yOi/view?usp=drive_linkhere’s the modules error
https://drive.google.com/file/d/1WlS4bDAUHcre0822DDx-7knYMTYwFMvN/view?usp=drive_linkpaulinapau
ParticipantI’m sorry, I don’t get it. Do you mean the Output channels table in the Administrator?
paulinapau
ParticipantI couldn’t change the rapid SCADA version I have now. So, I tried the exact channels available on rapid SCADA. But it still gives the same error as before. And yes, I already using the syntax in the article you gave me.
https://drive.google.com/drive/folders/1hpNNsM6xKIXFO2WhffcOnsR4R4ChhLLX?usp=sharing
I’m trying the input and output channels. By the way, I need to export the input one. Is it still possible?
