mrfy
  • in reply to: Unable to cast COM object of type ‘System.__ComObject’ #13290
    mrfy
    My fault..
    https://rapidscada.org/connecting-devices-using-opc-standard/
    1. Download and install OPC Core Components. (…)
    Mikhail please remove this topic.
    in reply to: OPC DA null values because bad quality. #13288
    mrfy
    Mi Miklail! I have done exctly same steps as you and it works!
    in reply to: OPC DA null values because bad quality. #13277
    mrfy
    Thank you, if you need to some support from my side please let me know.
    in reply to: OPC DA null values because bad quality. #13268
    mrfy
    Yes, I have got errors, below screens from my tests:
    1. If i choose Security Policy: “Basic256Sha256”:
    256
    2. But if I choose Security Policy: “Basic256”, then I have:
    unsu
    and if I close this popup by click on Ignore button, next one showed:
    notf
    Looks like RapidScada on default settings somegow supports Security Policy: “Basic256Sha256” but client cannot authorize.
    • This reply was modified 3 years, 1 month ago by mrfy.
    in reply to: OPC DA null values because bad quality. #13265
    mrfy
    Mikhail I’m wondering how to configure the opc server in rapidscad so that I can authorize SecurityPolicy Basic256Sha256 in the OPC client? I guess I have to set something in this XML file?
    in reply to: OPC DA null values because bad quality. #13260
    mrfy
    Mikhail I have question how I can configure SecurityPolicies on the RapidScada OPC UA Server. In OpcUaServer properties I can see only this options:
    opts
    But dont know what Configuration File is meaning, because in path “SCADA\ScadaComm\Config\DrvDsOpcUaServer.xml” there is default configuration xml?
    In this file I see some <SecurityPolicies> options, how to configure and then use it?
    config
    in reply to: OPC DA null values because bad quality. #13258
    mrfy
    Hi, yes in Pro Server if have have default limits 0 to 100 and values (Int16) was over 100, then I have ‘Bad’ quality status.I have changed limits and everything is ok now.
    in reply to: OPC DA null values because bad quality. #13253
    mrfy
    Bad quality is also received using 3rd party OPC Client, I have used UA Expert OPC Client for my tests. I need to reconfigure limits in OPC Server so now every values are in good ranges – that was the reason, every signal have default limits (0 to 100) but values are higher than limits.
    Thanks to that I’m able to communicate with remote server with opc da, like on diagram. Rapidscada rocks – it was very easy to configure! 🙂
    diagram
