aless
  • in reply to: How to link the inputs of my device and the tags ? #12811
    aless
    Nothing happens when i send a command on
    in reply to: How to link the inputs of my device and the tags ? #12804
    aless
    My bad it was on purpose that the signal wasn’t bound just to try one.
    I will reexplain my problem,
    all tags of my device are there :
    tags
    And as we can see there, all the leds are on:
    Scheme
    However my traffic light isn’t on :
    traffic light
    I want to link the input channel to the input of my controller himself connected to the traffic light as I have explain upper. But here, when I send an “on” command with the channel 101 for exemple, it dont send it to the controller and I don’t know how to link that.
    • This reply was modified 3 years, 5 months ago by aless.
    in reply to: How to link the inputs of my device and the tags ? #12794
    aless
    Ok now that i know :
    Hi, i dont understand how to connect tags from the device into rapid scada to my controler.
    I created a device that have 3 tags :
    3 tags
    And I want these 3 tags link to the entry of my controler schneider m221 :
    controler
    At the top of it you can see the input I0, I1, I2 and at the bottom the output Q0, Q1, Q2. These addresses can’t be modified and i can’t modified the addresses of the tags too.
    To sum up, i dont understand how to link the tags 1, 2, 3 of my device to the input I0, I1 ,I2 of my controler.
    MORE INFORMATIONS :
    The outputs of the controler itself are links to a traffic light :
    traffic light
    I0 to the green, I1 to the oragne, I2 to the red. We can see the scheme on the web application that I made :
    scheme on
    When I send a command, it will turn off the led on the scheme :
    sand command
    send command
    Result of the command here :
    result
    in reply to: How to link the inputs of my device and the tags ? #12793
    aless
    TRY :
    Traffic light
    in reply to: How to link the inputs of my device and the tags ? #12792
    aless
    I’m sorry i will send you that properly :
    3 tags
    controler
    MORE INFORMATIONS :
    traffic light
    scheme
    send command
    send command
    Result here :
    result
