ASA
ParticipantWhat I don’t get is how some of the command is correct but the rest is all wrong.
ASA
ParticipantYes it works correctly on windows i have tested the whole system on windows and it works.
Asa
ASA
ParticipantOk with the info above I have adjusted the .xml file address to 10 to see if there was a change in the signals received there was
The program log states it sent : 64 04 00 0A 00 16 58 33
That is correct howeverIn reality it sent :64 04 80 85 80 8b AC E6
Asa
ASA
ParticipantThe only error in the log is as follows it is listed multiple times
Date and time communication session with device 100 “A/W PLC”, type kpmodbus address 100 call number 100
Request element group
Send (8): 64 04 00 0A 00 16 58 33
Receive (0/5) :
Communication errorNow the device was not attached however it would not work anyway with those registers as they are unused.
Hope this helps
Asa
ASA
ParticipantHi
I should clarify the info I sent you was from a third party software looking at the signals recived by com port the problem I am haveing is the modbus first register is not the one I typed in if I change it the out put allso changes however it is all over the place the no of registers is allso wrong however all other relevent data is correct eg the device Id and function code as for the log ill attach it bellow.
Asa
ASA
ParticipantFirst off thank you for your help to date!
I have the usb sending commands to my plc
My new problem it’s the wrong ones on windows the scada send out 64 04 70 07 00 16 D3 30 this works
On pi it’s 64 04 B0 10 90 71 07 FE for some reason it’s changed I have checked the scadacomm config files and they appear to be the same what’s your thoughtsAsa
ASA
ParticipantAre you able to send a example com config page?
ASA
ParticipantWe’re should we use it?
ASA
ParticipantIt is listed on the list as /dev/ttyUSB0
Asa
ASA
ParticipantOk how do you get that?
ASA
ParticipantAccording to the logs com1 to com9 all had the same
ErrorError opening serial port no such file or directory
ASA
ParticipantOk the transferring of the files worked my next problem
I have lost connection to my device (rs232) I am useing a usb to rs232 converter the rpi says it’s device ttyUSB0 what am I doing wrong?Asa
ASA
ParticipantOk
How do you configure it ?
Is it with windows then copy across if so what files?asa
ASA
Participantoops my mistake please disregard my post as i am reading the addressing wrong on my devise……….
ASA
ASA
ParticipantThank you!
