lengzaii33
ParticipantUpdate: Using Mozilla Firefox shows the page well. I wonder why
lengzaii33
ParticipantHello, I have tried to login using internet explorer and it does successfully shown the login page. After I login it shows error to debug and the interface is crippled.
The log file for all four services is listed below,
-------------------------------------------------------------------------------- 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> ScadaServerService 5.1.4.1 is started 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> Check the existence of the data directories is completed successfully 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Check the existence of the configuration database files is completed successfully 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Input channels are read from the configuration database. Active channel count: 5 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Ouput channels are read from the configuration database 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Users are read from the configuration database 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Formulas are read from the configuration database 2021-05-11 03:47:10 <lengzaii-desktop><root><ACT> The formulas source code has been compiled 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Connection listener is started 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Start server 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Current data are not loaded 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> Connect to client 127.0.0.1 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> The user ScadaComm is successfully authenticated 2021-05-11 03:50:21 <lengzaii-desktop><root><ACT> Connect to client 127.0.0.1 2021-05-11 03:50:21 <lengzaii-desktop><root><ACT> The user ScadaWeb is successfully authenticated 2021-05-11 03:51:06 <lengzaii-desktop><root><ACT> Check username and password for admin. Result: passed 2021-05-11 03:52:06 <lengzaii-desktop><root><ACT> Disconnect client 127.0.0.1 -------------------------------------------------------------------------------- 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> ScadaCommService 5.2.1.2 is started 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Load device library: KpSimulator.dll 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Connect to SCADA-Server "localhost" 2021-05-11 03:47:09 <lengzaii-desktop><root><EXC> Error connecting to SCADA-Server: Connection refused 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Disconnect from SCADA-Server 2021-05-11 03:47:09 <lengzaii-desktop><root><ERR> Unable to start operation due to SCADA-Server communication error. Delay before trying again 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> Connect to SCADA-Server "localhost" 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> Start communication lines 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> Start receiving commands -------------------------------------------------------------------------------- 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> Agent 5.0.2.0 started 2021-05-11 03:47:10 <lengzaii-desktop><root><ACT> WCF service is started at http://localhost:10002/ScadaAgent/ScadaAgentSvc/ 2021-05-11 03:47:10 <lengzaii-desktop><root><ACT> Start logic processing -------------------------------------------------------------------------------- 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> ScadaServerService 5.1.4.1 is started 2021-05-11 03:47:08 <lengzaii-desktop><root><ACT> Check the existence of the data directories is completed successfully 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Check the existence of the configuration database files is completed successfully 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Input channels are read from the configuration database. Active channel count: 5 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Ouput channels are read from the configuration database 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Users are read from the configuration database 2021-05-11 03:47:09 <lengzaii-desktop><root><ACT> Formulas are read from the configuration database 2021-05-11 03:47:10 <lengzaii-desktop><root><ACT> The formulas source code has been compiled 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Connection listener is started 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Start server 2021-05-11 03:47:11 <lengzaii-desktop><root><ACT> Current data are not loaded 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> Connect to client 127.0.0.1 2021-05-11 03:47:19 <lengzaii-desktop><root><ACT> The user ScadaComm is successfully authenticated 2021-05-11 03:50:21 <lengzaii-desktop><root><ACT> Connect to client 127.0.0.1 2021-05-11 03:50:21 <lengzaii-desktop><root><ACT> The user ScadaWeb is successfully authenticated 2021-05-11 03:51:06 <lengzaii-desktop><root><ACT> Check username and password for admin. Result: passed 2021-05-11 03:52:06 <lengzaii-desktop><root><ACT> Disconnect client 127.0.0.1-
This reply was modified 5 years, 5 months ago by
lengzaii33.
lengzaii33
ParticipantHello, I have performed sudo apt-get autoremove mono, and then I redone the step shown in the mono-project above, and confirmed the version of mono-devel to be 6.12.0.122-0xamarin1+ubuntu2004b1.
However, the same problem persists after reboot
Should I delete and perform everything again? Please advice thanks-
lengzaii33.
lengzaii33
ParticipantI install mono using sudo apt-get install mono-complete, it has errors at first, so i rebooted and try again and it seems succeeded.
Does raspbian differ from Ubuntu in the process?
