March 10, 2021 at 11:42 am in reply to: Why ModDBExport Module is not publishing realtime or current data? #8478
ibrahim.nezar
ParticipantOpen your project in Administrator and find the Calculator.
Sorry I’m new to RapidScada. I didn’t understand what is a Calculator? How to find it?
Do you mean generator? If yes, I found it, but I don’t see Channel in the list. Note that I have 9 input channels and 0 output channels in the Configuration Database -> System.
March 9, 2021 at 1:54 pm in reply to: Why ModDBExport Module is not publishing realtime or current data? #8458ibrahim.nezar
ParticipantI mean the data is dumped to the db and datetime is the same for all records and never get updated or new data inserted.
March 9, 2021 at 1:53 pm in reply to: Why ModDBExport Module is not publishing realtime or current data? #8457ibrahim.nezar
ParticipantHere is the content of the ModDBExport.log
2021-03-09 16:47:19 Module ModDBExport is stopped
2021-03-09 16:47:22 Start ModDBExport module
2021-03-09 16:49:07 Module ModDBExport is stopped
2021-03-09 16:49:10 Start ModDBExport moduleAnd ModDBExport.txt
Export Data Module
State: normalData Sources
1. MySQL – 127.0.0.1; state: normal; in queue cur/arc/ev: 0/0/0; exported cur/arc/ev: 9/0/0; skipped cur/arc/ev: 0/0/0And you are right, without the output channel after I restarted the service, data is dumped to the DB.
But still not real time input to the db.
What do you think?
March 9, 2021 at 5:49 am in reply to: Why ModDBExport Module is not publishing realtime or current data? #8447ibrahim.nezar
I attached to you all the screenshots of the current setup in this link:
Google Drive Folder Attachments
Some facts about our setup:
– I’m just reading input registers from the modbus device, so only input channels are configured, hence not output channels or commands.
– When I do manual export to the data from the ModDBExport.dll properties, I got the current data dumped to the MySQL db on the cnldata table.
– I’m using root user on mysql db and the db is living on the same RapidScada machine.Appreciate your support
Best.
This reply was modified 5 years, 7 months ago by
ibrahim.nezar.
ibrahim.nezar.
ibrahim.nezar.
