quintelosky
ParticipantOk. Now I’m working, when I return to my house I will check.
Can you try the commands and send values?
Many thanks
quintelosky
ParticipantOk
Now ( 6:05 gmt ), the opc ua server is running to the same ip ( opc.tcp://83.42.220.118:4840 ). I don’t shutdown the pc. If you will use the siemens opc ua client .net to verifiy the connection and blocks, run as administrator
Many thanks
quintelosky
ParticipantAgain. Sorry.
I’m doing some tests. I modified the file c:\scada\projects\myproject\instances\default\scadacomm\config\kpopcua_001.xml adding the nodes and I can read the values<?xml version="1.0" encoding="utf-8"?> <KpOpcUa> <ConnectionOptions> <ServerUrl>opc.tcp://83.42.220.118:4840</ServerUrl> <SecurityMode>None</SecurityMode> <SecurityPolicy>None</SecurityPolicy> <AuthenticationMode>Anonymous</AuthenticationMode> <Username /> <Password>C8080E774B59B0C6694063BDE2428352</Password> </ConnectionOptions> <Subscriptions> <Subscription active="true" displayName="" publishingInterval="1000"> <Item active="true" nodeID="ns=3;s="DB800 TBox_Data"."W_Don_Guarin"."DG_FT2_F"" displayName="DG_FT2_F" isArray="false" arrayLen="1" cnlNum="0" /> <Item active="true" nodeID="ns=3;s="DB16 Señales Analogicas"."TurbidezEntrada"."MaxEscalat"" displayName="Turbid_escalado_max" isArray="false" arrayLen="1" cnlNum="0" /> </Subscription> </Subscriptions> <Commands> <Command nodeID="ns=3;s="DB16 Señales Analogicas"."TurbidezEntrada"."MaxEscalat"" displayName="Turbid_escalado_max" dataType="System.Double" cmdNum="1" /> </Commands> </KpOpcUa>But the command don’t work, I can’t change values I think is a problem with dataType because kpopcua can’t add commands with other opc server simulator too (indicate datatype not recognized).
Can you check it?
Some images with errors using opc ua server simulator ( https://integrationobjects.com/sioth-opc/sioth-opc-unified-architecture/opc-ua-server-simulator/ )
https://ibb.co/QP4B1Z7
https://ibb.co/sQGD86j
https://ibb.co/VQCdGDS
https://ibb.co/zFnvvxL
https://ibb.co/58KtsvBMany thanks for all
quintelosky
ParticipantEDIT3: If you want, first you can connect with siemens opc ua server:
https://mega.nz/file/YRFiBByB#DLzKOsxGXZYNmbk7lUpq1D0_dRokkCObRP3pEmk6nAY
I used these program to check connection via internet and works fine, and you can view all blocks and valuesquintelosky
ParticipantEDT2: Ok, I can connect to my opc server via other pc in other public ip. You can connect without problems
quintelosky
ParticipantHi
Well, I continue firing with my lan. Now, I can connect in my lan to my plcsim from all computers, but I don’t know if a external pc can connect to my server opc ua.
I configured in my router: Port Forwarding (4840 to my plcsim ip), and dmz (to mi plcsim ip)
I sent you a pm with my public ip. I don’t know what hour is good for you, but I connect my computer now ( 16:52 gmt )
EDIT: Upps, I can’t send a pm, my ip: 83.42.220.118
This reply was modified 5 years, 8 months ago by
quintelosky.
quintelosky
ParticipantHi
How money?
I don’t know connect my siemens plcsim advance running in a virtual machine to public ip internet. I need know, how can I do
quintelosky
ParticipantHi
It is impossible. Is a corporate lan. But, I do these tests in my house with two virtual machines: one running virtual plc (tia portal 15 + plc advance sim) and other running rapidscada (the screen is my personal pc). I can give you access to my computer and you can view the problem.
These is the sourcecode of the siemens opc ua .net client:
https://mega.nz/file/hIsFAADS#Yk9pRPYym_jFtayqJgCaaXqljCpG-46oAAKwaV25txAMany thanks. If you can repair these problem, rapidscada will be my scada for many projects with siemens s7-1200 and s7-1500
