January 9, 2019 at 10:00 am in reply to: SCADAComm stop attempt to reconnect when communication failed #4828
jkb
Participantsorry for late reply. just emailed to info@
December 27, 2018 at 6:36 am in reply to: SCADAComm stop attempt to reconnect when communication failed #4786jkb
Participantposted to him in the github. no reply so far. I did some small changes to the code to have it reconnect. It works like a charm.
December 12, 2018 at 6:16 pm in reply to: SCADAComm stop attempt to reconnect when communication failed #4733jkb
ParticipantHi Mikhail,
After looking at the code further. It is KpMQTT implementation that does not reconnect and resubscribe to MQTT Broker once the communication failed.here is the log by the way.
2018-12-12 17:00:20 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:20 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:20 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:20 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:21 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:21 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:21 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:21 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:22 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:22 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:22 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:22 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:23 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:23 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:23 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:23 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:24 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:24 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:24 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:24 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:25 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:25 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.2018-12-12 17:00:25 Communication session with the Device 42 “MQTT Driver”, type: KpMQTT
2018-12-12 17:00:25 Error communicating with the device: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.Thanks.
