baharsahin
ParticipantI got the point now, thank you !
baharsahin
ParticipantI changed according to your advice : https://www.dropbox.com/s/sd5nljc5koxudz3/input%20channels.JPG?dl=0
But the results are still wrong.
I did not understand, why I dont need formula for channel 434. I want to assign the 8th bit of register 1001 to channel 434. and 9th bit of register 1001 to channel 435… continues likes this.
baharsahin
Participanthere is a screenshot of my input channel settings:
baharsahin
ParticipantFor example I have 2 registers for my digital inputs (1001-1002).
and their signal numbers are 354 and 355.I have digital inputs at input registers from 423 to 448 ( they are in order). They all have different signal numbers.
I selected channel type of the first digital input as discrete and the rest of them as calculated discrete. In this case, I can JUST read the value of register 1001’s 0th bit. The rest is not correct.When we add an element group to read registers, they have 1 unique signal number.
Then when I create input channels, I am creating 16 input channels to read 16 different bits of 1 register. Then how should I bound them?? It is reading just one bit of it.In communicator I can see that the register is just bound to one input channel but I want to give it to 16 input registers. How this is possible?
baharsahin
ParticipantOkey if I use discrete for the first channel then I will use calculated discrete for the followings.
how does the software understand the queue, from channel numbers or from signal numbers? And What if the channel numbers of these are not sequential ? Is this a problem?
baharsahin
It turned out that my device cannot reply more than 50 requests at once. Thats why I made my groups with 50 elements.
Also I read the 16 bits register with holding registers function once and assigned the same register to 16 input channels with different names and by using formula, I got 16 different bits of that register and assigned them accordingly to the input channels. Now the speed is OK.
Thank you very much for your help!baharsahin
ParticipantI will change the translate table and my input channels accordingly and check the speed again
baharsahin
ParticipantI have some registers that have different parameters on each bit. For example 1001 (holding register) has 16 bits and each is a different parameter. Since I could not enter an address like 1001.08 to the address part, I am reading this register 16 times with different register names and then I am entering a formula on input channels part.
If I can read this register once and create 16 different parameters with different names, it may be faster. Will doing this configuration affect and How can I do this?
baharsahin
ParticipantI guess it is not reading 480 parameters at once because all these 480 parameters are seperated in different Element Groups. I have 1 element group with 46 parameters, the others have parameters less than that.
baharsahin
ParticipantCould you please explain this in more detail : To set the settings property is an extraordinary interview after sending the command.
All possible parameters are in an element group. So, I think they are being polled together?
Is there any other way to change poll method to group?
