t_bidaud
I have configured the connection with my data base
I want to upload in my data base the current dta from the scada server.
When I use the generator I recieve just one data
I want to recieve data/min.
Thank you for your helpingt_bidaud
I able to tranfert data with the generator.
But I can’t sent automatically data from server
t_bidaud
Ok i did it, I put the insert command in current, archive & event.
I create a data base with the other command.
But when I try SELECT * FROM clndata; I have nothing.
I forced to use mysql.
This is the screenshot:
t_bidaud
I send you an email with screenshots
t_bidaud
ParticipantI chose Oracle in Add data source
In connection I have :
Serveur localhost
Database test_bdd.sql
User t_bidaud
BDD123
Connexion String
Server=localhost/test_bdd.sql;UserID=t_bidaud;Password=BDD123And in Current Data I check Export and I put in SQL window the SQL code in documentation.
But I have any new line in my Oracle database after.
t_bidaud
ParticipantI don’t understand where I connect the database in SCADA Serveur _ Modules _ ModBDExport.dll _ Connection.
And when I write the SQL code in documentation. -
