Windows 10 install issue
Forum Home Forums Installation Issues Windows 10 install issue
  • This topic has 4 replies, 2 voices, and was last updated 7 years ago by snz.
  • #2039
    snz
    I am having issues installing Rapid Scada on a windows 10 64bit. The install indicates that Static contents is not available. I have enabled this in windows feature but still having no success. Does anyone have a solution for this? Thank you
    Please see below for install log.
    Start Rapid SCADA 5.1.1 installation 27-Mar-17 5:43:07 PM
    Install Server application
    Directory C:\SCADA\ScadaServer\ has to be cleared
    Installation of Server application has completed with a error
    Install Communicator application
    Directory C:\SCADA\ScadaComm\ has to be cleared
    Installation of Communicator application has completed with a error
    Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    Before Webstation installation it’s required to install the following Internet Information Services (IIS) components:
    Static Content
    For this purpose go to
    Check Microsoft SQL Server Compact 3.5
    Unzip files from ScadaAdmin.zip
    Create shortcut Administrator
    Installation of Administrator application has completed successfully
    Install Table Editor application
    Unzip files from ScadaTableEditor.zip
    Create shortcut Table Editor
    Installation of Table Editor application has completed successfully
    Check Microsoft Silverlight 5
    Install Scheme Editor application
    Unzip files from ScadaSchemeEditor.zip
    Create shortcut Scheme Editor
    Installation of Scheme Editor application has completed successfully
    Installation has completed with errors 27-Mar-17 5:43:08 PM
    #2041
    Please provide a screenshot of chosen Windows features. Use postimage.org or similar for publishing screenshots.
    #2047
    snz
    Thanks for the prompt reply Mikhail, Please below for screencaps. Let me know if you need more details.
    cap1
    cap2
    #2049
    You enabled Static Content Compression but not enabled Common HTTP Features > Static Content. Just enable it and install the Webstation app.
    #2051
    snz
    Thank You Mikhail, That worked good.
    == Resolved ==
