Forum Home › Forums › Installation Issues › SCADA-Web Installation › Webs configuration: set Password
- This topic has 14 replies, 4 voices, and was last updated 6 years, 6 months ago by Mikhail.
June 14, 2017 at 6:45 am #2257traudenParticipant
Hello everyone.
Help me please. In the Web configuration I set password and browser logout. Then I login with set password but I was unsuccessful
(Server is unavailable.). How can I login to Webscada to change a password?- This topic was modified 6 years, 10 months ago by trauden.
June 14, 2017 at 8:11 am #2259MikhailModeratorHi,
The easiest way is changing password by editing C:\SCADA\ScadaWeb\config\WebSettings.xml in your favorite text editor.June 14, 2017 at 10:02 am #2260traudenParticipantThanks Mikhail,
I tried to change passwords for login to web. But it failed.
It possible to change passwords in website? Mikhail.June 14, 2017 at 11:47 am #2261MikhailModeratorTo change the password you need to login. You can change the password in the configuration database to make them matched.
After password is changed in XML, you need to restart the web application. You can do it using IIS Administration console or by restarting the PC.Don’t need.- This reply was modified 6 years, 10 months ago by Mikhail.
June 14, 2017 at 11:49 am #2263MikhailModeratorWhat is written in the log file?
June 15, 2017 at 4:08 am #2264traudenParticipantThanks Mikhail,
July 29, 2017 at 5:32 am #2426AndrewYGParticipantHello, ScadaWeb development, how to configure the server and common
July 31, 2017 at 7:40 am #2427MikhailModeratorHello,
Please create a new topic and specify your question to make it understandable.August 2, 2017 at 7:47 am #2439AndrewYGParticipantApplication Error
Details:
文件“/plugins/Scheme/Scheme.aspx”不存在。August 2, 2017 at 12:52 pm #2452MikhailModeratorThis error means that the file C:\SCADA\ScadaWeb\plugins\Scheme\Scheme.aspx does not exists. You should check if it’s true that this file is missing.
Can you create a new topic in this forum? I recommend providing link to a screenshot of a problem, it helps to find out the cause faster.August 10, 2017 at 3:19 am #2476AndrewYGParticipantApplication Error
Details:
Type “Scada.Web.Plugins.Scheme.WFrmScheme” is not clear: it may come from the assembly “C: \ Users \ Administrator \ Desktop \ web_syy \ AutoCarCtrlSysWeb2017 \ AutoCarCtrlSysWeb2017 \ cores \ ScadaWeb \ ScadaWebShell5 \ bin \ PlgScheme.DLL” or program Set “C: \ Users \ Administrator \ Desktop \ web_syy \ AutoCarCtrlSysWeb2017 \ AutoCarCtrlSysWeb2017 \ cores \ ScadaWeb \ ScadaWebShell5 \ bin \ ScadaWebShell5.DLL”. Please specify the assembly explicitly in the type name.August 10, 2017 at 6:24 am #2477MikhailModeratorYou have to reinstall the Webstation app. There is a mess of the old and the new files.
September 30, 2017 at 8:27 am #2632hethongscada62ParticipantHello Mr.Mikhail.
The Administrator Application was installed. Interface is used Russian. I want change it to English, but on screen appears “SCADA-Administrator has stopped working”. Could you help me to resolve this problem.
Thanks and best regards
Hoanghan1962October 2, 2017 at 9:34 am #2634MikhailModeratorHello,
Download the Linux distributive. Then run SetCulture.exe on your Windows computer. It allows to easy switch culture. Set en-GB culture.
Could you provide screenshot of the “SCADA-Administrator has stopped working” error?October 2, 2017 at 9:36 am #2635MikhailModeratorSetCulture.exe is a console application. Run it from the command line.
