Forum Home › Forums › Installation Issues › SCADA-Web Installation › Web Application on Windows Server 2012 R2
- This topic has 11 replies, 4 voices, and was last updated 5 years, 1 month ago by mitesh.
March 15, 2017 at 3:46 am #2005DragonFireParticipant
Before anything else, I would like to say thank you for creating this awesome piece of software. It does what I need it to do, minus a small issue, but, again, thanks for creating RapidSCADA.
Now, for my issue, I am having a difficult time getting the web application to work on a Windows Server 2012 R2 machine. I’ve read all the documentation and watched all the videos as well on the topic but as most know, Windows Server is slightly different than its Desktop counterparts. The issue seems to be getting all the IIS parts right. Since Server 2012 R2 is neither Windows 7 or Windows 10, how do I go about installing the right .NET version and IIS components? I get this any time I try to connect to the web server (this is just a generic image of my issue):
Should I go the route of following the Windows 7 IIS setup instructions since Windows Server 2012 R2 doesn’t have access to ASP.NET 4.6? Thank you for your time.
- This topic was modified 7 years, 1 month ago by DragonFire.
March 15, 2017 at 7:56 am #2007MikhailModeratorMarch 16, 2017 at 3:47 am #2008DragonFireParticipantHere are a few screenshots that cover my config in Server Manager and in IIS Manager:
<br/><br/>
<br/><br/>
<br/><br/>
<br/><br/>
<br />forum image hosting<br /><br />Hope these help. Thanks for the fast response!
- This reply was modified 7 years, 1 month ago by DragonFire.
March 16, 2017 at 5:50 am #2010MikhailModeratorThank you.
Also you have to switch on ASP.NET 4.5 and HTTP Activation for WCF 4.5
What do you see by the link http://localhost ?- This reply was modified 7 years, 1 month ago by Mikhail.
March 17, 2017 at 2:20 am #2016DragonFireParticipantJanuary 23, 2019 at 10:22 pm #4938aluy069ParticipantI say thanks you guys because you did a great piece of software.
I have 3 questions:
1-. How to install everything (Server, communicator, webstation, administrator, table editor and scheme editor) in a Windows Server 2012 R2.
2-. I have SQL 2018 installed. Can I use it instead of Microsoft SQL Server Compact 3.5.?
3-. If Yes Question number 2, how to do it? By the way is running is a different server than the one running the Rapid Scada
Regards
January 24, 2019 at 1:10 pm #4940MikhailModerator1. Before running Rapid SCADA setup, you should switch on the features of Windows Server 2012 R2. If you provide link to their screenshot, I’ll write what features to select.
2. Microsoft SQL Server Compact 3.5 is used for configuration only, not for data archive. You can’t change it to SQL 2018. In the future we will get rid of SQL Server Compact.
January 24, 2019 at 3:12 pm #4943aluy069ParticipantThanks i follow the win 7 setting and it worked 🙂
2-. could you please guide me how to do the data archive in SQL2018. My scenario is i have two server: Server A is the web server, it hold the configuration and is web server. Server B is the SQL 2018.
regards
January 25, 2019 at 5:07 pm #4946February 26, 2019 at 7:14 am #5071miteshParticipantHi Mikhail,
In Web Application i clicked Collapse menu option. so now i am not able to see Main menu, views,server equipment and demo options. could you please help me to recover that options.
Regards,
MiteshFebruary 26, 2019 at 3:11 pm #5074MikhailModeratorHi,
Look for the Menu button in the top left corner of the web page. If there is no such button, provide a screenshot.
February 27, 2019 at 5:48 am #5077miteshParticipantHi Mikhail,
I got it and Thank you for your support.
