Server is unavailable
Forum Home Forums Installation Issues SCADA-Web Installation Server is unavailable
This topic contains 14 replies, has 2 voices, and was last updated by Mikhail Mikhail 1 week, 6 days ago.
Viewing 15 posts - 1 through 15 (of 15 total)
  • #2841
    LPG57
    After migrating to Scada 5.4.1, I can’t log in on the Scada web page, get the message “Server is unavailable”.
    I used the same user as I used with the old version (admin).
    ScadaserverSVC log:
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> ScadaServerService 5.1.0.2 is started
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 43
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Ouput channels are read from the configuration database
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Users are read from the configuration database
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Formulas are read from the configuration database
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> The formulas source code has been compiled
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Connection listener is started
    2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Start server
    2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> Current data are loaded
    2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2017-11-22 22:22:03 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 22:22:03 <SERVER7><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2017-11-22 22:22:30 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 22:22:30 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-22 22:42:25 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
    2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
    2017-11-22 22:49:04 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 22:49:04 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
    2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
    2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
    2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
    ScadaServerSvc.txt:
    SCADA-Server
    Started : 22/11/2017 22:21:50
    Execution time : 1.20:12:49
    State : normal
    Version : 5.1.0.2
    Connected Clients (1)
    1. 127.0.0.1; ScadaComm (Application); activity: 18:34:39
    ScadaWeb.log
    2017-11-22 23:09:08 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: 54ao1isfna1zamq3si5xtkqo
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> User name or password is incorrect
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    Scada.ScadaException: Unable to receive the configuration database modification time.
    at Scada.Client.DataCache.RefreshBaseTables()
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> Unsuccessful login attempt: peder – Server is unavailable. IP address: ::1
    2017-11-22 23:29:22 <SERVER7><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: 54ao1isfna1zamq3si5xtkqo
    2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ERR> User name or password is incorrect
    2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2017-11-24 18:25:00 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: 83.142.103.76. Session: lxw0v20243tol44phkjh34ul
    2017-11-24 18:25:10 <SERVER7><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2017-11-24 18:25:10 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2017-11-24 18:25:10 <SERVER7><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 83.142.103.76
    #2842
    Please open C:\SCADA\ScadaWeb\config\WebSettings.xml in a text editor and check CommSettings section. These are the connection parameters for the web app. Can you provide them here?
    #2843
    Also check CPU load of ScadaServerSvc.exe.
    #2844
    LPG57
    Hello Mikhail,
    The CPU load of ScadaServerSvc.exe is currently 0
    and here is the WebSettings.xml:
    <?xml version=”1.0″ encoding=”utf-8″ ?>
    – <WebSettings>
    <Param name=”SrezRefrFreq” value=”5″ descr=”Values refresh frequency, sec” />
    <Param name=”EventRefrFreq” value=”5″ descr=”Events refresh frequency, sec” />
    <Param name=”EventCnt” value=”50″ descr=”Display events count” />
    <Param name=”EventFltr” value=”true” descr=”Set ‘View’ events filter by default” />
    <Param name=”DiagBreak” value=”90″ descr=”Distance between points on the diagramm to make a break, sec” />
    <Param name=”CmdEnabled” value=”true” descr=”Enable commands” />
    <Param name=”SimpleCmd” value=”false” descr=”Simple commands sending” />
    <Param name=”RemEnabled” value=”false” descr=”Enable to remember logged on user” />
    </WebSettings>
    #2845
    LPG57
    and here is the CommSettings.xml
    – <CommSettings>
    <Param name=”ServerHost” value=”localhost” descr=”SCADA-Server host or IP address” />
    <Param name=”ServerPort” value=”10000″ descr=”SCADA-Server TCP port number” />
    <Param name=”ServerUser” value=”ScadaWeb” descr=”User name for the connection” />
    <Param name=”ServerPwd” value=”12345″ descr=”User password for the connection” />
    <Param name=”ServerTimeout” value=”10000″ descr=”Response timeout, ms” />
    </CommSettings>
    I tried also with user “ScadaWeb”, but the result was the same
    #2849
    The format of the WebSettings.xml file was changed. You should take the new one from the distributive.
    You don’t need CommSettings.xml for the web app no more.
    #2856
    LPG57
    Following the instructions above solved the login problem – thanks’
    However, when logged in the following message appear:
    “The requested view does not exist or you have insufficient rights to access it.”
    I can open the tables in the table editor.
    #2857
    LPG57
    I solved the issue above, found out that there were differences in the Interface table between the old and new version.
    Now I only wonders how the “Rights” table “Interface Objects” field is populated? In the drop down list, there is only the demo objects, not the tables I built?
    #2858
    LPG57
    The issue with the rights table is solve, but now I have a new problem:
    When connecting with the web station, it works OK while doing it directly on the server itself, but when doing it from a PC outside the domain, I can login, but the tables are not updated with data and the message “Error updating current data” appear. After 10 secs, I’m thrown out.
    Login performed 10:21 was on localhost and succeeded, login performed 10:23 was from a remote PC and failed.
    ScadaWeb.log
    2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Request SCADA-Server state
    2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: b3knixrzaedaicjuaoku3wml
    2017-11-27 10:21:57 <SERVER7><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
    2017-11-27 10:21:57 <SERVER7><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: b3knixrzaedaicjuaoku3wml
    2017-11-27 10:22:27 <SERVER7><DefaultAppPool><ACT> Logout: admin. IP address: ::1
    2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> Request SCADA-Server state
    2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 199.64.75.186
    2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> User information has been updated. IP address: 199.64.75.186. Session: lxw0v20243tol44phkjh34ul
    ScadaServerSvc.log
    2017-11-27 10:21:54 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
    2017-11-27 10:21:54 <SERVER7><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
    2017-11-27 10:21:57 <SERVER7><SYSTEM><ACT> Check user admin name and password. Result: passed
    2017-11-27 10:23:22 <SERVER7><SYSTEM><ACT> Check user admin name and password. Result: passed
    #2860
    Does it work from another PC in the same network?
    Please press F12 in a browser and provide logs (or screenshots) from the Console and Network tabs.
    #2880
    LPG57
    If I’m connect using http://servername7scada from another computer within the domain, it works OK. But if I’m from the same computer use the external https://domainname/scada, it doesn’t work.
    #2888
    If you need HTTPS, you have to do special settings on IIS. See this
    #2897
    LPG57
    There was already a certificate for port 443 for this web site, so when creating another one, I couldn’t log on remotely anymore. (Running SBS 2011)
    #2898
    HTTPS is more tricky. To solve this issue, a remote connection is required – this is a commercial service.
    #2899
    Does https://localhost/ work?
