Server error while first time running the web
Forum Home Forums Installation Issues SCADA-Web Installation Server error while first time running the web
  • #1586
    medvdev
    Dear Sir,
    I have tried to install .net 4.6.1 but it does not show up in windows feature list , but on installed program it is there, any way when I ran the server and tried to acces web the error shows comes up is:-
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: Unrecognized attribute ‘targetFramework’. Note that attribute names are case-sensitive.
    Source Error:
    Line 2: <configuration>
    Line 3: <system.web>
    Line 4: <compilation targetFramework=”3.5.1″ />
    Line 5: </system.web>
    Line 6:
    Source File: C:\SCADA\ScadaWebBeta\web.config Line: 4
    Version Information: Microsoft .NET Framework Version:2.0.50727.5485; ASP.NET Version:2.0.50727.5491 ..
    System config is win 7 professional service pack 1 64 bit os.
    #1587
    Find in the system and run Aspnet_regiis.exe -i
    Then open IIS management console and switch default application pool (or the pool used by Scada web app) to .NET 4 if it is not set to it.
    • This reply was modified 7 years, 7 months ago by Mikhail.
