Sending Email Notifications
Forum Home Forums Rapid SCADA on Raspberry Pi Sending Email Notifications
This topic contains 4 replies, has 3 voices, and was last updated by Mikhail Mikhail 1 year, 6 months ago.
  • #815
    Since Rapid SCADA v4.5.6 it is possible to setup email notifications. Emails are sent by KpEmail.dll
    Before sending the emails you should install a sertificate because Mono doesn’t trust any server by default.
    If you use gmail run these commands:
    mozroots --import --ask-remove
    certmgr -ssl smtps://smtp.gmail.com:465
    Then restart Rapid SCADA sevices.
    See details at
    http://www.mono-project.com/docs/faq/security/
    http://stackoverflow.com/questions/4148019/authentication-or-decryption-has-failed-when-sending-mail-to-gmail-using-ssl
    #828
    pragnya
    Hi. I am a beginer in SCADA systems and trying to understand how the whole system works. I am not able to run the scadaAdmin.exe. Please help
    #829
    I’ll help you. Just create a new topic in Installation Issues
    #846
    scodina
    It’s not clear where I have to run that sertificate, cmd? Can you write a step by step list on how to create an alarm event from a discrete chanel and send the alarm by email or SMS, it will be very useful thanks
    #852
    It is for Raspberry Pi only. Use command line.
    Please start a new topic with you question about configuring in Understanding the Software subforum, please.
