Forum Home › Forums › Uncategorized Issues › Scheme loading failed.
- This topic has 3 replies, 2 voices, and was last updated 6 years, 7 months ago by braveheartjhl.
August 30, 2017 at 3:20 am #2528braveheartjhlParticipant
hello
Once I have logged with admin account, when I try to visualize the default scheme, the next error appears:
Scheme loading failed. Try to reload scheme
Error updating eventsJavaScript error:
Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:16 Request ‘ClientApiSvc.svc/GetEvents’ failed: 404 (Not Found)
logFailedRequest @ utils.js:151
scheme.js:18 11:07:16 Start loading scheme
plugins/Scheme/SchemeSvc.svc/GetSchemeProps?viewID=2&viewStamp=0&_=1504062436578 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:16 Request ‘SchemeSvc.svc/GetSchemeProps’ failed: 404 (Not Found)
scheme.js:44 11:07:16 Scheme loading failed
(anonymous) @ scheme.js:44
ClientApiSvc.svc/GetEvents?year=2017&month=8&day=30&cnlNums=%20&viewIDs=%20&viewID=2&lastCount=100&startEvNum=1&dataAge=0&_=1504062436066 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:17 Request ‘ClientApiSvc.svc/GetEvents’ failed: 404 (Not Found)
ClientApiSvc.svc/GetEvents?year=2017&month=8&day=30&cnlNums=%20&viewIDs=%20&viewID=2&lastCount=100&startEvNum=1&dataAge=0&_=1504062436067 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:18 Request ‘ClientApiSvc.svc/GetEvents’ failed: 404 (Not Found)
ClientApiSvc.svc/GetEvents?year=2017&month=8&day=30&cnlNums=%20&viewIDs=%20&viewID=2&lastCount=100&startEvNum=1&dataAge=0&_=1504062436068 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:19 Request ‘ClientApiSvc.svc/GetEvents’ failed: 404 (Not Found)
ClientApiSvc.svc/GetEvents?year=2017&month=8&day=30&cnlNums=%20&viewIDs=%20&viewID=2&lastCount=100&startEvNum=1&dataAge=0&_=1504062436069 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:151 11:07:20 Request ‘ClientApiSvc.svc/GetEvents’ failed: 404 (Not Found)
logFailedRequest @ utils.js:151My Windows version is ‘Windows Server 2012R2’.
How can I solve it?
Thanks everybody!August 30, 2017 at 2:50 pm #2538MikhailModeratorHi,
Usually such errors caused when Windows Communication Foundation (WCF) not installed. Please check the installed components. If you provide screenshots, I can compare them with my server.August 30, 2017 at 2:51 pm #2539MikhailModeratorDo table views also show error?
August 31, 2017 at 7:22 am #2541braveheartjhlParticipantHello Mikhail
I installed WCF,the problem is solved.
Thanks for all the help!
