Would you kindly point me to how can I start adding some javascript code to the scheme? I understand now is possible but haven’t found documentation about it.
I would like to add a gauge i.e. this one http://justgage.com/ and be able to connect it with rapid Scada in a scheme. Is that possible?
Currently, we develop the possibility to add custom components to schemes. When we finish it, you will get straightforward way of doing it. For now, you should modify the existing Scheme plugin that is possible but not clear.
Can you let me know if it’s possible to help in the development in any way? Is there any branch that holds the current work on this subject?
Thank you very much for your helpfulness. Due to the changes affect the core of scheme engine, it’s difficult to involve new developer. Your help will be very useful in creation of new different components when schemes can support them.
