- This topic has 3 replies, 2 voices, and was last updated 6 years, 9 months ago by .
Forum Home › Forums › Uncategorized Issues › Schematic Editor fails to open schematic file
Hi there,
I have been designing a schematic view file using schematic editor. It was all good until lately after a modification and save action, the editor can not load the file anymore and throws the below message:
WCF Service error: [MaxRecievedMessageSizeExceeded]
Arguments: 10485760
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem…
Loading…
Please help as I badly need to edit the view to implement changes.
PT
What version of Scheme Editor do you use? The actual version is 5.1.0.1. If you use the earlier version, please update.
When the issue is fixed, I recommend to check your images and decrease their sizes if possible.
Thanks Mikhail. What is the best way to decrease the file size? What elements are the most resource intensive?
PT
Images. Choose properties of the scheme, find images property and open images dialog. Check size of each image. If size of an image more than 100 KB, try to compress it in an image editor.
