Forum Home › Forums › Installation Issues › Scada web Config Error
- This topic has 9 replies, 2 voices, and was last updated 7 years, 7 months ago by Mikhail.
September 15, 2016 at 1:52 am #1610subairiParticipant
Can’t open Scada web Config What Wrong with instalation?
Error loading server Connection setting file:
C:\Scada\ScadawebConfig\CommSettings.xlm not found
C:\Scada\ScadawebConfig\ViewSettings.xlm not foundand first instalation i have an error with message:
Check the configuration of Internet Information Services (IIS)
Go to
Control Panel -> Programs -> Turn Windows features on or off
and make sure that WCF Services -> HTTP Activation feature is installed for .NET Framework 4+
Before SCADA-Web installation it’s required to install the following Internet Information Services (IIS) components:
Static Content
For this purpose go to
Control Panel -> Programs -> Turn Windows features on or offSeptember 15, 2016 at 6:39 am #1611MikhailModeratorDid you follow the recommendations in the error message?
Was SCADA-Web successfully installed by the next attempt?
Please post screenshots of the errors.September 15, 2016 at 9:43 am #1612subairiParticipantI’m already working according to the instructions, but still error.
where do I screenshot error?
September 15, 2016 at 10:39 am #1613MikhailModeratoruse postimage.org for publish screenshots
September 15, 2016 at 8:45 pm #1614subairiParticipantthis is log setup
Start Rapid SCADA 4.5.7 installation 16/09/2016 3:43:09
Create directory C:\SCADA\
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA\Check Microsoft SQL Server Compact 3.5
Install SCADA-Administrator:
Unzip files from ScadaAdmin.zip
Create shortcut SCADA-Administrator
SCADA-Administrator installation has completed successfullyInstall SCADA-Server:
Unzip files from ScadaServer.zip
Create shortcut SCADA-Server
Install service ScadaServerService
SCADA-Server installation has completed successfullyInstall SCADA-Communicator:
Unzip files from ScadaComm.zip
Create shortcut SCADA-Communicator
Install service ScadaCommService
SCADA-Communicator installation has completed successfullyCheck the configuration of Internet Information Services (IIS)
Go to
Static Content
Control Panel -> Programs -> Turn Windows features on or offInstall SCADA-Web Configurator:
Unzip files from ScadaWebConfig.zip
Create shortcut SCADA-Web Configurator
SCADA-Web Configurator installation has completed successfullyInstall SCADA-Table Editor:
Unzip files from ScadaTableEditor.zip
Create shortcut SCADA-Table Editor
SCADA-Table Editor installation has completed successfullyInstall SCADA-Scheme Editor:
Unzip files from ScadaSchemeEditor.zip
Create shortcut SCADA-Scheme Editor
SCADA-Scheme Editor installation has completed successfullyInstallation has completed with errors 16/09/2016 3:43:11
September 15, 2016 at 8:54 pm #1615subairiParticipantScreenshot from my PC: Control Panel -> Programs -> Turn Windows features on or off
https://postimg.org/image/w0zn9h66n/
screenshot error web config
https://postimg.org/image/5revt0evp/<img src=”https://postimg.org/image/5revt0evp/” alt=”error web config” />
September 16, 2016 at 6:07 am #1616MikhailModeratorSCADA-Web app was not installed.
You have to switch on Common HTTP Features -> Static Content option.
Also switch off all the options for .NET 3.5September 21, 2016 at 2:33 am #1618subairiParticipantmy folder “config” at C:\SCADA\ScadaWebConfig not found
is this true?September 21, 2016 at 2:35 am #1619subairiParticipantSeptember 21, 2016 at 6:24 am #1620MikhailModeratorAccording to your screenshot I can say that SCADA-Web is not installed in C:\SCADA\ScadaWeb
What are the current state of installation?
I can install Rapid SCADA remotely, if you’d like. It is a commercial service.
