Rapid SCADA on Orange Pi 2 plus
Forum Home Forums Rapid SCADA on Raspberry Pi Rapid SCADA on Orange Pi 2 plus
This topic contains 11 replies, has 2 voices, and was last updated by Mikhail Mikhail 1 year, 6 months ago.
Viewing 12 posts - 1 through 12 (of 12 total)
  • #1078
    JonatasP
    I’m trying to use the “Rapid Scada” with an “Orange Pi 2 Plus” card,i followed the tuturial installation. When I try to connect with the login and passwords that i set, I get the following error:
    Unable to login: Server is unavailable.
    How to solve?
    #1079
    Look at C:\SCADA\ScadaServer\Log
    What are in log files?
    I strongly recommend to use RAM drives for log folders in case of using SD card.
    #1080
    JonatasP
    In Linux the log is located in “/ etc / scada / Scada Server / log / ScadaServer / Svc.log” right?
    The content is as follows:
    2016-05-05 08:51:04 <orangepiplus2><root><ACT> ScadaServerService 4.5.0.5 is started
    2016-05-05 08:51:05 <orangepiplus2><root><ACT> Check the existence of the data directories is completed successfully
    2016-05-05 08:51:05 <orangepiplus2><root><ACT> Check the existence of the configuration database files is completed successfully
    2016-05-05 08:51:06 <orangepiplus2><root><ACT> Input channels are read from the configuration database. Active channel count: 14
    2016-05-05 08:51:06 <orangepiplus2><root><ACT> Ouput channels are read from the configuration database
    2016-05-05 08:51:06 <orangepiplus2><root><ACT> Users are read from the configuration database
    2016-05-05 08:51:06 <orangepiplus2><root><ACT> Formulas are read from the configuration database
    2016-05-05 08:51:08 <orangepiplus2><root><ERR> Error compiling the source code of the formulas:
    Line 79, column 31: error CS0589: Internal compiler error during parsingSystem.FormatException: Input string was not in the correct format
    Line 0, column 0: error :   at System.Double.Parse (System.String s, NumberStyles style, IFormatProvider provider) [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.Tokenizer.adjust_real (TypeCode t, Location loc) [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.Tokenizer.is_number (Int32 c, Boolean dotLead) [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.Tokenizer.xtoken () [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.Tokenizer.token () [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.CSharpParser.yyparse (yyInput yyLex) [0x00000] in <filename unknown>:0
    Line 0, column 0: error :   at Mono.CSharp.CSharpParser.parse () [0x00000] in <filename unknown>:0
    See the file /etc/scada/ScadaServer/Log/CalcEngine.cs with the source code
    2016-05-05 08:51:09 <orangepiplus2><root><ERR> Normal program execution is impossible.
    #1081
    JonatasP
    The SO is installed in internal memory of Orange Pi.
    #1082
    Such error appears on Germany localization because of Mono bug. What OS culture do you use?
    #1083
    JonatasP
    The operational system is armbian(in english), but the locations and language are portuguese-brazil -charset UTF8.
    What i can do to solve the problem?
    #1086
    Do you use comma as decimal separator?
    I think the most simple way to switch location and language back to English and check whether error disappear or not.
    #1087
    The cause that Mono can’t compile the line 79
    initialCmdVal = 0.0;
    that is shown in ScadaServer/Log/CalcEngine.cs
    #1095
    JonatasP
    There is no possibility to make an adjustment in the software to fix it?
    I will switch location and language back to english, in the meantime.
    #1096
    First of all, let’s make sure about the reason. Please write about the result after changing localization.
    #1105
    JonatasP
    Changed language using:
    sudo dpkg-reconfigure locales
    from pt_BR.UTF-8 UTF-8
    to en_US.UTF-8 UTF-8
    And now i can sucesfull login in rapid scada.
    #1108
    Thank you for the info.
    The issue is entered in the tracker in order to be resolved in the future.
