"," of numbers Forum Home › Forums › Understanding the Software › "," of numbers This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by Mikhail. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts October 24, 2017 at 3:50 pm #2690 JoaoParticipant Hi all; Its possible I remove the “,” when numbers above 1000 are showed in schemes? exemple: 1,000 > 1000 This topic was modified 6 years, 5 months ago by Joao. This topic was modified 6 years, 5 months ago by Joao. October 25, 2017 at 5:37 pm #2697 MikhailModerator Hi, Formatting depend’s on the culture that is set in Webstation settings and this culture parameters of the server. For example, en-GB. October 25, 2017 at 7:10 pm #2703 JoaoParticipant The Rapid SCADA only have culture en-GB and ru-RU. Exist an en-GB.xml file that I can modificate this number format manually? October 26, 2017 at 9:11 am #2704 MikhailModerator If you set en-US or pt-BR, for example, formatting will be changed but the software loads the existing en-GB files. November 22, 2017 at 10:40 am #2827 peter_fParticipant This is my problem too. I changed the culture to en-US with no effect. pt-BR is the same. Is there an other point where I have to do something? November 22, 2017 at 5:21 pm #2829 MikhailModerator The visible difference between en-GB and en-US is the date pattern. English is Day-Month-Year. US is Month-Day-Year. Does it change? How you want to format values? Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
