Forum Home › Forums › Installation Issues › New Version 5.1.1, installation on Win-7 32 bit, Default Silverlite is x64
- This topic has 8 replies, 3 voices, and was last updated 6 years, 10 months ago by Mikhail.
May 7, 2017 at 9:48 am #2131KurlekarParticipant
During installation of New Version Rapid Scada 5.1.1, installation on Win-7 32 bit system, Default Silverlite installation is x64, and installation of silverlite is aborted.
I have downloaded silverlite and renamed it as Silverlight_x64″ x32 and completed the installation.Is this okay?
New Version of RapidScada 5.1.1 can work on Win7_32 bit? or I have to install Win7_64 bit?May 8, 2017 at 7:26 am #2133May 8, 2017 at 7:38 am #2135KurlekarParticipantDone, it is working alright,
June 16, 2017 at 10:57 am #2265jaypatel5213Participanti have a problem to installation on win-7 32 bit.
plz see thisStart Rapid SCADA 5.1.1 installation 16-06-2017 15:51:34
Check version of Microsoft .NET FrameworkInstall Server application
Directory C:\SCADA\ScadaServer\ has to be cleared
Directory C:\SCADA\ArchiveDAT\ has to be cleared
Directory C:\SCADA\ArchiveDATCopy\ has to be cleared
Directory C:\SCADA\Interface\ has to be cleared
Installation of Server application has completed with a errorInstall Communicator application
Directory C:\SCADA\ScadaComm\ has to be cleared
Installation of Communicator application has completed with a errorCheck the configuration of Internet Information Services (IIS)
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Directory C:\SCADA\ScadaWeb\ has to be cleared
installation of Webstation application has completed with a errorCheck Microsoft SQL Server Compact 3.5
Directory C:\SCADA\ScadaAdmin\ has to be cleared
Directory C:\SCADA\BaseDAT\ has to be cleared
Directory C:\SCADA\BaseSDF\ has to be cleared
Installation of Administrator application has completed with a errorInstall Table Editor application
Directory C:\SCADA\ScadaTableEditor\ has to be cleared
Installation of Table Editor application has completed with a errorCheck Microsoft Silverlight 5
Install Scheme Editor application
Directory C:\SCADA\ScadaSchemeEditor\ has to be cleared
Installation of Scheme Editor application has completed with a errorInstallation has completed with errors 16-06-2017 15:51:49
Please restart the computeri try manyway but not solw this….
plz help me..June 16, 2017 at 12:44 pm #2266MikhailModeratorIt means that Rapid SCADA already installed. If you need to reinstall it, uninstall the existing one.
June 16, 2017 at 12:58 pm #2267jaypatel5213ParticipantNo,
not installed.June 16, 2017 at 1:01 pm #2268jaypatel5213ParticipantMY os system is windows 7 ultimate 32-bit.
not soweing in program file folder it’s releted.June 19, 2017 at 5:35 am #2270MikhailModeratorPlease check the following:
1. Does the folder C:\SCADA\ exist?
2. Run services.msc
Do ScadaCommService and ScadaServerService exist?June 19, 2017 at 5:36 am #2271MikhailModeratorIn this case may be it’s faster to install Rapid SCADA manually as written at http://doc.rapidscada.net/content/en/installation-and-run/manual-installation.html
