ModAutoControl executing a binary file on event ? Forum Home › Forums › Development and Integration › ModAutoControl executing a binary file on event ? This topic has 4 replies, 3 voices, and was last updated 3 years, 6 months ago by Mikhail. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts December 15, 2016 at 1:03 pm #1835 inpelsaParticipant Hi Mikhail, I would like RapidScada to execute a .EXE o .CMD file at some point (input channel value or status = 0) to be able to do more complex tasks. Is there any way to accomplish this? the only way I think of is with SNMP commands send to a SNMP server…. Thanks! December 16, 2016 at 8:18 am #1837 MikhailModerator Hi, You can try using in a formula the following code: System.Diagnostics.Process.Start("C:\you_file.bat"); Please tell about the result. December 16, 2016 at 8:19 am #1838 MikhailModerator Be careful, if the statement is true on every program cycle, you will run a lot of processes. October 3, 2020 at 9:56 am #7346 KrzysztofParticipant Is it possible to run a PowerShell script with a command sent by ModAutoControl? October 5, 2020 at 12:07 pm #7354 MikhailModerator Starting scripts feature requires development of a module for SCADA-Server. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
