Hi, i have some doubt.I have lock in http://localhos/scada on admin user and select Server room (scheme) page. microsoft silverlight message box pop up but i already installed the microsoft silverlight and i can open ScadaSchemeEditor without a problem. May i know what is the problem?
I think, Silverlight depends on browser only. Try IE )
I’m not sure that schemes will work on Raspberry because of WCF support issues in Mono .NET Framework. It is required additional research which shall be done during the development of the next major version of SCADA-Web.
Hi Mikhail, I have try use IE to open it but an error message shown:
WCF service error:[HttpWebRequest_WebException_RemoteServer]
Arguments: NotFound
Debugging resource string are unavailable. Often the key and arguments provide sufficient information to diagnose t…
This is what i meant in the previous message. If you have some time you could try to find how to setup WCF on Raspberry. Anyway, SCADA-Web will be redesigned in the future. At the current time we can use table views of data.
