Hi
I’m just start to learn RapidSCADA after install package following How_to_install.txt I can login to SCADAweb but cannot execute communicator in Raspbian linux. In /opt/scada/ScadaComm/ has .exe file but I cannot use to run on linux. Has any way to run communicator on linux.
.exe is OK for Linux when you use Mono Framework.
If you performed the installation steps correctly, the daemons were created and Server and Communicator start automatically after restart RPi. You should check logs.
There is no UI on Linux, because it is a server. You should configure the software on Windows, and then copy configuration to Linux. I hope we will simplify this process in the future.
