Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › How to control GPIO for raspberry?
- This topic has 9 replies, 4 voices, and was last updated 6 years, 10 months ago by Mikhail.
October 20, 2015 at 10:24 am #618jeffwooParticipant
May i know how to control GPIO for raspberry? I have a small project, need to use raspberry as a human machine interface communicate with arduino thru modbus serial. arduino will capture the realworld signal and processing. And raspberry will use to key in parameter and display the result. This project will have data logger to store the data to USB storage on raspberry and export to excel file. Is that possible to be done in Rapid Scada? Please advice how to do it ? Thank you very much.
October 20, 2015 at 10:52 am #619MikhailModeratorYes, your task can be solved by Rapid SCADA.
Are you going to use GPIO of Arduino and use Raspberry as a server only?
Or Raspberry also should work with its own GPIO?October 20, 2015 at 10:54 am #620jeffwooParticipantThank you very much for fast reply. Currently plan to use GPIO of arduino and Raspberry as server only. but is it possible to control raspberry GPIO as well?
October 20, 2015 at 10:54 am #621jeffwooParticipantMay i know how to do it?
October 20, 2015 at 11:12 am #622MikhailModeratorOctober 20, 2015 at 11:13 am #623MikhailModeratorI recommend to implement Modbus prorocol on your Arduino. In this case you can easily connect it to Rapid SCADA.
July 31, 2016 at 2:29 pm #1498sarindaParticipantHi,
Can you please tell me a Modbus library for Arduino which is compatible with RapidScada. I am having troubles with communicating with an arduino.I tried following code. It works with QMB (for modbus checking) but no data is received by rapidScada.
#include <modbus.h> #include <modbusDevice.h> #include <modbusRegBank.h> #include <modbusSlave.h> /* PINS Add more registers if needed Digital input pins 2,3,4,5,6,7 Digital output pins 8,9,12,13 Analog output pins 10,11 (PWM) Analog input pins 0,1,2,3,4,5 */ modbusDevice regBank; modbusSlave slave; int AI0,AI1,AI2,AI3,AI4,AI5; void setup() { regBank.setId(1); ///Set Slave ID //Add Digital Input registers regBank.add(10002); regBank.add(10003); regBank.add(10004); regBank.add(10005); regBank.add(10006); regBank.add(10007); // Add Digital Output registers regBank.add(8); regBank.add(9); regBank.add(12); regBank.add(13); //Analog input registers regBank.add(30001); regBank.add(30002); regBank.add(30003); regBank.add(30004); regBank.add(30005); regBank.add(30006); //Analog Output registers regBank.add(40010); regBank.add(40011); slave._device = ®Bank; slave.setBaud(9600); pinMode(2,INPUT); pinMode(3,INPUT); pinMode(4,INPUT); pinMode(5,INPUT); pinMode(6,INPUT); pinMode(7,INPUT); pinMode(8,OUTPUT); pinMode(9,OUTPUT); pinMode(12,OUTPUT); pinMode(13,OUTPUT); } void loop(){ while(1){ //Digital Input byte DI2 = digitalRead(2); if (DI2 >= 1)regBank.set(10002,1); if (DI2 <= 0)regBank.set(10002,0); byte DI3 = digitalRead(3); if (DI3 >= 1)regBank.set(10003,1); if (DI3 <= 0)regBank.set(10003,0); byte DI4 = digitalRead(4); if (DI4 >= 1)regBank.set(10004,1); if (DI4 <= 0)regBank.set(10004,0); byte DI5 = digitalRead(5); if (DI5 >= 1)regBank.set(10005,1); if (DI5 <= 0)regBank.set(10005,0); byte DI6 = digitalRead(6); if (DI6 >= 1)regBank.set(10006,1); if (DI6 <= 0)regBank.set(10006,0); byte DI7 = digitalRead(7); if (DI7 >= 1)regBank.set(10007,1); if (DI7 <= 0)regBank.set(10007,0); //Digital output int DO8 = regBank.get(8); if (DO8 <= 0 && digitalRead(8) == HIGH)digitalWrite(8,LOW); if (DO8 >= 1 && digitalRead(8) == LOW)digitalWrite(8,HIGH); int DO9 = regBank.get(9); if (DO9 <= 0 && digitalRead(9) == HIGH)digitalWrite(9,LOW); if (DO9 >= 1 && digitalRead(9) == LOW)digitalWrite(9,HIGH); int DO12 = regBank.get(12); if (DO12 <= 0 && digitalRead(12) == HIGH)digitalWrite(12,LOW); if (DO12 >= 1 && digitalRead(12) == LOW)digitalWrite(12,HIGH); int DO13 = regBank.get(13); if (DO13 <= 0 && digitalRead(13) == HIGH)digitalWrite(13,LOW); if (DO13 >= 1 && digitalRead(13) == LOW)digitalWrite(13,HIGH); //Analog input ***READ Twice deliberately AI0 = analogRead(0); delay(10); AI0 = analogRead(0); regBank.set(30001, (word) AI0); delay(10); AI1 = analogRead(1); delay(10); AI1 = analogRead(1); regBank.set(30002, (word) AI1); delay(10); AI2 = analogRead(2); delay(10); AI2 = analogRead(2); regBank.set(30003, (word) AI2); delay(10); AI3 = analogRead(3); delay(10); AI3 = analogRead(3); regBank.set(30004, (word) AI3); delay(10); AI4 = analogRead(4); delay(10); AI4 = analogRead(4); regBank.set(30005, (word) AI4); delay(10); AI5 = analogRead(5); delay(10); AI5 = analogRead(5); regBank.set(30006, (word) AI5); delay(10); //Analog output word AO10 = regBank.get(40010); analogWrite(10,AO10); delay(10); word AO11 = regBank.get(40011); analogWrite(11,AO11); delay(10); slave.run(); } }
August 1, 2016 at 2:03 pm #1500MikhailModeratorHi,
This topic has another subject. Please create a new one. I can’t recommend you a library but I’ll try to help you to establish connection if you post communication line log.
June 22, 2017 at 6:57 am #2285manjey73Participanthttps://github.com/Manjey73/OpnenKPs/tree/master/KpRpi3 (readme – online translate)
https://github.com/Manjey73/OpnenKPs/releases/tag/KpRpi3 (use gpio 5-27, in archive use all gpio)June 22, 2017 at 11:30 am #2289 -
