How can I do
This topic contains 29 replies, has 4 voices, and was last updated by Mikhail Mikhail 3 weeks, 2 days ago.
Viewing 15 posts - 1 through 15 (of 30 total)
  • #2601
    Mistral
    Mistral
    If I get a temperature greater than 100 how can I pass the volt from 0 to 5? … (i\’m a neophyte with rapidscada plugs and an arduino mega 2560 with ethernet via modbus)
    #2602
    You need to do signal scaling from 0-100 to 0-5 ?
    Describe the task more precisely
    To scale the signal, I used the formula
    double Scaler (double input, double in_min, double in_max, double out_min, double out_max)
    double out1 = 0;
    double out2 = 0;
    double output = 0;
    double diff = in_max - in_min;
    if (diff != 0)
    if (input > in_max) out1 = in_max;
    else out1 = input;
    if (in_min > out1) out2 = in_min;
    else out2 = out1;
    output = (out_max - out_min) / diff * (out2 - in_min) + out_min;
    return output;
    Scaler(Val(121), 0, 100, 0, 5)
    If the value of the measured signal in channel 121 is higher than 100, the output signal will be equal to 5 in this example, below 0, the output signal will be equal to 0
    • This reply was modified 2 months, 2 weeks ago by  manjey73.
    #2604
    Mistral
    Mistral
    thanks … I apologize … I use an automatic translator … anyway I meant that I have a temperature input that if exceeded a certain value I have to activate a small engine connected to the plc that starts giving 5volt energy
    #2605
    Hi all,
    You need Automatic Control Module.
    Firstly, make sure that you can successfully send command manually, then use the module to do it automatically.
    #2606
    Mistral
    Mistral
    Hi Mikhail … I have the module but I do not know how to set the formula in rapidscada … in the arduino sketch i have implemented …
    if (Mb.MbData[6]>1000)
    voltageWrite(A0_5, 5000);
    voltageWrite(A0_6, 0);
    else
    voltageWrite(A0_6, 5000);
    voltageWrite(A0_5, 0);
    that works, can you help me?
    #2607
    If you already implemented to work on the Arduino for input variable then you only need the Automatic Control Module to send data of temperature change using Modbus just multiplying it by 10
    You scetch is compared with the value 1000
    Then everything will make your program in Arduino
    Or you want to make an analog program the Arduino directly on Rapid Scada ?
    #2609
    Mistral
    Mistral
    Thanks, but I would like to implement temperature control (swinging from 900 to 1100) on rapidscada so that if it exceeds 1000, “voltageWrite (A0_5, 5000) is activated”. I do not know how I could better clarify, sorry.
    #2610
    You need a formula for Hysteresis ?
    If it is difficult to explain in words, maybe draw a picture of what should be connected and put on the exchanger ?
    #2611
    Mistral
    Mistral
    Hi manjey73, thanks for the availability and patience of a RapidScada neophyte, I include three images representing 1) electrical input and output PLCs, 2) input channel and ScadaCommunicator administrator table, 3) Scada Scheme I did for tests where I see the simulated temperature I receive in addition to a dynamic picture that changes when the temperature changes. Now I would like to realize with rapidscada that if the temperature exceeds a certain value rises to 5Volt A0.5. I hope that what’s said is useful to suggest a solution.
    https://webmail.aruba.it/cgi-bin/ajaxems?ACT_FIL_DL=1&PUBLICUID=Y29tcGFueUBtaXN0cmFsaW5mb3JtYXRpY2EuaXQvNy4zLzE1MDY0NDg2NTA=
    https://webmail.aruba.it/cgi-bin/ajaxems?ACT_FIL_DL=1&PUBLICUID=Y29tcGFueUBtaXN0cmFsaW5mb3JtYXRpY2EuaXQvNy4yLzE1MDY0NDg3MTc=
    https://webmail.aruba.it/cgi-bin/ajaxems?ACT_FIL_DL=1&PUBLICUID=Y29tcGFueUBtaXN0cmFsaW5mb3JtYXRpY2EuaXQvNy4xLzE1MDY0NDg3NDA=
    #2612
    You need Automatic Control Modul.
    Do I understand correctly that you have a PC with RapidScada and modules input / output and you want to control directly from RapidScada ?
    The module serves for automatic control of external devices.
    To avoid permanent switching off of the desired additional channel with the formula of Hysteresis and already according of this channel to send a command to the output module.
    int[] HysNum = new int[1];
    bool[] Hys = new bool[1];
    public double Hysteresis(double inCnl, double low, double high)
    bool q = Val(CnlNum) > 0;
    int res = Array.IndexOf(HysNum, CnlNum);
    if (res == -1)
    res = HysNum.Length;
    Array.Resize(ref HysNum, res+1);
    Array.Resize(ref Hys, res+1);
    HysNum[res] = CnlNum;
    Hys[res] = q;
    if (inCnl < low) Hys[res] = true;
    if (inCnl > high) Hys[res] = false;
    return Convert.ToDouble(Hys[res]);
    example – Hysteresis(Val(414),950,1050) —- Val(414) this sensor channel
    The module configures for triggering the channel, with one value you pass to the device value to 5v the other to 0v the value
    #2613
    Note: the current version of the module includes the deadband option that is close to hysteresis.
    #2614
    Mistral,
    Try to configure Automatic Control Module and publish its screenshots here.
    #2615
    Mistral
    Mistral
    Hi manjey73,
    i have the “Automatic Control Module”, i have rapidscada’s pc.
    I’m evaluating the script you sent me.
    But to make sure I explained my intent to you, I am sending you a list of a simple Arduino sketch where I realized what I would like to get from rapidscada scheme.
    https://webmail.aruba.it/cgi-bin/ajaxems?ACT_FIL_DL=1&PUBLICUID=Y29tcGFueUBtaXN0cmFsaW5mb3JtYXRpY2EuaXQvNy40LzE1MDY0OTY0NTA=
    #2616
    You are not using Arduino with RapidScada, and use some kind of analog output ?
    Well, and send commands directly to the module output with Automatic Control Modul
    In the presence of Hysteresis in the module you do not need any formula.
    In manual mode you can force to work the module as you want ? Here’s the same commands send through an automatic how to activate or deactivate.
    #2617
    Mistral
    Mistral
    Hi Mikhail,
    i send you the current setting of “Automatic Control Module” … i hope i have suggestions … thank you
    https://webmail.aruba.it/cgi-bin/ajaxems?ACT_FIL_DL=1&PUBLICUID=Y29tcGFueUBtaXN0cmFsaW5mb3JtYXRpY2EuaXQvNy41LzE1MDY0OTgwODc=
