Hello, I have established modbus TCP connection with an Allen Bradley Micro 820.
I have mapped 3 registers. Temperature (Int), Temp_Real(Real) and Temp_Real_100(Real).
I can view Temperature, as it is.
The other 2 not. I get results that I can’t understand.
Please provide the additional info:
1. Screenshot of Modbus template
2. Screenshot of the values that you receive (Device Data tab in Communicator).
3. What values you expect?
Probably, you should try different order of bytes (in Modbus template) to decode floats. For example, 2301
