Generate sound on station for alarming
Forum Home Forums Understanding the Software Using Formulas Generate sound on station for alarming
  • #237
    OlegA
    How I can generate any sound without web pages?
    Can I use Beep function in formula for alarming?
    I tried to use System.Media.SystemSounds.Beep.Play(). It doesn’t work.
    #238
    Formulas are calculated on a server machine by SCADA-Server service.
    Most likely Windows doesn’t allow services to access a sound card.
    What device should play a sound in your case?
    #239
    OlegA
    Yes, it’s sound card.
    #240
    OlegA
    Do you know a way of get access to sound card for SCADA-Server?
    #241
    Try the following:
    1. Create a simple console application that play a sound. You can use Microsoft Visual Studio 2013 Community Edition.
    2. In the formula call
    System.Diagnostics.Process.Start(“C:\\MyPath\\PlaySound.exe”);
    3. Be careful using such formulas. Do not use them for calculated channels.
    Please, write here about the result.
