Error: The keyset is not defined in SCADA Administrator
Forum Home Forums Installation Issues Error: The keyset is not defined in SCADA Administrator
This topic contains 3 replies, has 2 voices, and was last updated by Mikhail Mikhail 1 month ago.
  • #2938
    mitesh
    Dear Mikhail,
    I got following Error in SCADA Administrator on Windows 7.
    Error: Error backing up the configuration database: The Keyset is not defined.
    #2941
    This is the first time when such error occurs.
    Please watch the details in C:\SCADA\ScadaAdmin\ScadaAdmin.err and copy them here.
    #2942
    mitesh
    Hi Mikhail,
    ScadaAdmin.err
    2017-12-11 19:38:22 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
    The keyset is not defined.
    2017-12-11 19:42:23 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
    2017-12-12 11:52:56 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
    2017-12-12 12:56:28 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
    #2953
    I recommend to switch off automatic backup of the database (in the app settings) and back it up manually by copying C:\SCADA\BaseSDF\ScadaBase.sdf
