Forum Home › Forums › Installation Issues › Error on the web browser
- This topic has 6 replies, 4 voices, and was last updated 7 years, 3 months ago by Mikhail.
December 10, 2015 at 1:55 am #783jeesloParticipant
Hi Mitkail
Now updated latest wing I have very often this error is in Russian do not understand ..
http://subefotos.com/ver/?4babbe5f190acc5767b762d7c63f79b7o.jpg
I tested Firefox browsers, Opera and IE, initiated session after a while hanging the page, change the IIS recycle time of 1740-0 and I need to have all the time the session started. I also selected in the Scada-web remember check, The error started after logging in about 7 or 8 hours I think
To resolve this problem in version 4.5 I overwrote the contents of \ScadaWebConfig \ScadaWeb and folders with the version 4.4, therefore I inform you that there is an error I look but could not find maybe you can.
regards
December 10, 2015 at 9:56 am #784MikhailModeratorHi,
Do schemes of v.4.4 work without this timeout error?
Please remind me what OS do you use?
If the error occurs, how can you eliminate it? Do you have to restart browser or IIS or it disappears by itself?December 10, 2015 at 9:16 pm #785jeesloParticipantHi Mikhail
Do V.4.4 schemes of work without esta timeout error?
– If all the schemes I did in V. 4.4Please remind me what OS do you use?
– I have two different Windows Server 2008 R2 and Windows 7 systemsIf the mistake OCCURS, how can you Eliminate it? Do you have to restart IIS or browser by itself or it Disappears?
– Simple Web browser restart the client manually-As you discuss the problem ends do this and it works perfectly !!!
To resolve this problem in version 4.5 I overwrote the contents of \ScadaWebConfig \ScadaWeb and folders with the version 4.4, therefore I inform you that there is an error I look but could not find maybe you can.December 12, 2015 at 7:24 am #786MikhailModeratorHi,
This error rarely happen before. It is strange that changing version back to 4.4 solves the error. The mechanism of data exchange hasn’t been changed in 4.5. I hope that in the next version of SCADA-Web this error will disappear due to new approach of internal web application structure.
January 3, 2016 at 2:13 pm #804babeshkinParticipantMikhail I solved this problem in the same way but I didn’t raise the issue before. I did not read this topic before also. I found the way by installing old version and in web-browser everything was OK. After installing new version I substituted the content of “Scada Web Config” folder from old package.
По ходу не только я такой шаманщик….January 4, 2017 at 7:15 pm #1856chanchalsharma@live.inParticipantSir, web application getting logout automatically within 30 sec, after showing “error updating hourly data”
January 5, 2017 at 8:17 am #1857MikhailModeratorIt usually happens if WCF for .NET Framework 4+ is not installed. See this video
