Forum Home › Forums › Installation Issues › SCADA-Web Installation › Error installing ScadaWeb Win10
- This topic has 10 replies, 4 voices, and was last updated 3 years, 9 months ago by In_Sync.
July 31, 2016 at 5:32 am #1495nmambreParticipant
Running the installer, it complains of not finding IIS, even though it is installed (I can see localhost welcome page).
I had to use the procedure of the scadaweb beta to get it working.Maybe the installer doesn’t recognize installed .NET version?
Start Rapid SCADA 4.5.7 installation 31/7/2016 01:02:04
Create directory C:\SCADA\
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA\Check Microsoft SQL Server Compact 3.5
Install SCADA-Administrator:
Unzip files from ScadaAdmin.zip
Create shortcut SCADA-Administrator
SCADA-Administrator installation has completed successfullyInstall SCADA-Server:
Unzip files from ScadaServer.zip
Create shortcut SCADA-Server
Install service ScadaServerService
SCADA-Server installation has completed successfullyInstall SCADA-Communicator:
Unzip files from ScadaComm.zip
Create shortcut SCADA-Communicator
Install service ScadaCommService
SCADA-Communicator installation has completed successfullyCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel -> Programs -> Turn Windows features on or off
and make sure that WCF Services -> HTTP Activation feature is installed for .NET Framework 4+
Before SCADA-Web installation it’s required to install the following Internet Information Services (IIS) components:
.NET Extensibility,
ASP.NET
For this purpose go to
Control Panel -> Programs -> Turn Windows features on or offInstall SCADA-Web Configurator:
Unzip files from ScadaWebConfig.zip
Create shortcut SCADA-Web Configurator
SCADA-Web Configurator installation has completed successfullyInstall SCADA-Table Editor:
Unzip files from ScadaTableEditor.zip
Create shortcut SCADA-Table Editor
SCADA-Table Editor installation has completed successfullyInstall SCADA-Scheme Editor:
Unzip files from ScadaSchemeEditor.zip
Create shortcut SCADA-Scheme Editor
SCADA-Scheme Editor installation has completed successfullyInstallation has completed with errors 31/7/2016 01:02:15
July 31, 2016 at 5:41 am #1496MikhailModeratorHi,
Also you need to check that WCF Services -> HTTP Activation feature is installed for .NET Framework 4+.
Is it installed?May be you could publish the screensot of your Windows features window?
July 31, 2016 at 8:04 am #1497nmambreParticipantThe screenshot is in my first post, and WCF is installed (at the top of the screenshot)
August 1, 2016 at 1:57 pm #1499MikhailModeratorYour settings seem OK. Most likely the installer is not enough clever. Please, do manual installation which is described in the appropriate PDF included in the package. It’s quick.
August 1, 2016 at 2:26 pm #1501nmambreParticipantOK, I’ll try that later, I’m on Linux machine now.
I also have to read rest of manuals, to understand workflow, so that I know how to change project and do modifications on the examples that you provided.August 1, 2016 at 7:09 pm #1502MikhailModeratorOK.
By the way, the new web app beta works on Linux as well as on Windows.December 20, 2017 at 2:18 am #2971NanoParticipanthi….
I got a problem like this“Installation of Server application has completed with a error
Install Communicator application
Directory C:\SCADA\ScadaComm\ has to be cleared
Installation of Communicator application has completed with a errorCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Directory C:\SCADA\ScadaWeb\ has to be cleared
installation of Webstation application has completed with a errorCheck Microsoft SQL Server Compact 3.5
Directory C:\SCADA\ScadaAdmin\ has to be cleared
Directory C:\SCADA\BaseDAT\ has to be cleared
Directory C:\SCADA\BaseSDF\ has to be cleared
Installation of Administrator application has completed with a errorInstall Table Editor application
Directory C:\SCADA\ScadaTableEditor\ has to be cleared
Installation of Table Editor application has completed with a errorInstall Scheme Editor application
Directory C:\SCADA\ScadaSchemeEditor\ has to be cleared
Installation of Scheme Editor application has completed with a errorInstallation has completed with errors 12/20/2017 9:06:03 AM
Please restart the computer”please solusion
December 20, 2017 at 7:38 am #2972MikhailModeratorHi,
First of all, remove the existing installation of Rapid SCADA.
Open Windows features list and check the required options needed for the web app, see images at http://doc.rapidscada.net/content/en/installation-and-run/software-installation.htmlJune 18, 2020 at 9:21 pm #6917In_SyncParticipantHi,
I have similar issues but your link isnt working
Cheers M
June 19, 2020 at 9:15 am #6918MikhailModeratorHi,
June 19, 2020 at 9:32 am #6920In_SyncParticipantThanks!
