Destination port for web portal
Forum Home Forums Installation Issues SCADA-Web Installation Destination port for web portal
This topic contains 3 replies, has 2 voices, and was last updated by  hybrid 1 week, 2 days ago.
  • #2902
    hybrid
    Hi there,
    I’ve got the scada web portal setup and working on a computer. I can access it locally and from other devices on the network by going to x.x.x.x/scada without issue.
    I have a fixed IP address so I’d like to set up port forwarding on my router to redirect certain traffic to the scada portal.
    i.e. Any traffic into y.static.ip.y:12345 is forwarded to x.x.x.x/scada
    What destination port should i use ?
    On the computer running rapid scada, if i go to 127.0.0.1:80 it bring me to the IIS Welcome page.
    #2903
    hybrid
    Actually what I think I need to do is set the /scada web page as the default website when going to localhost:80. (instead of the IIS Welcome)
    Could you tell me how to do this, or point me in the right direction?
    #2904
    Yes, you should forward to the port 80.
    To make the address to http://yourip
    – Open IIS administration console
    – Remove the existing Scada web application in the IIS administration console
    – Open parameters of the default web site and set its path to C:\SCADA\ScadaWeb
    #2916
    hybrid
    Perfect, that did it, thanks.
