Hello all,
I need to display a graphic containing 5 different channels.
I’ve used Chart Pro plugin, which allows me to manually add the channels to the graph.
But, as I need to deliver this to an operator, I’d like to have a Shortcut to the graphic already containing the 5 channels (so he doesn’t have to do it manually everytime).
Mikhail suggested me that, as the Chart is essentially an Hyperlink in a WebBrowser, I should be able to add it in the Tree of Views.
But I can´t find the way to do it. I’ve tried adding it in the “Interface” section of the Administrator, but it says the link has too many characters.
Any hint will be appreciated.
Kind regards
Martin
