Connecting to a remote device
Forum Home Forums Communicating with Devices Connecting to a remote device
This topic contains 2 replies, has 2 voices, and was last updated by  Riadh 2 weeks, 1 day ago.
  • #2633
    Riadh
    Hi collegues,
    I’m new to rapidscada, after a short training I could connect a device (a power meter) to the software with a direct ethernet connection with the pc.
    Now I assigned a static ip address to my device, so I can access to its internal webserver through the web.
    I went then to rapidscada and I changed its local ip address into the public ip address, i kept the port 502, it did not connect. can anyone tell me what’s wrong ?
    #2636
    Please paste communication line log here.
    You should check firewall. Probably, outgoing connection to TCP port 502 is prohibited. Web interface uses port 80 which is usually permitted.
    #2641
    Riadh
    Hi Mikhail, I have set the port on 443 and it worked, thanks.
